4 Replies Latest reply on Oct 7, 2014 2:09 PM by MatLac
    Best way to create a multi-step validation process
    MatLac Level 3
      I am writing a multi step validation process and I was wondering what is the best method to have it operate on the value.  What I have:
      As a custom validation script, in that order:
      1- Calls a function that looks if the value is part of a particular array
      2- Calls a function that regroup some tests
           2a- function test1()
           2b- function test2()
           2c- function test3()
           2d- function test4()
      What I have now is every test ends as 'event.rc = false' when they fail which is what I need but I also need to stop the entire validation process.  As an example, if the value fails test2() and gets a "you have failed test 2" alert, I don't want to call test3() and test4() since it is already decided that it failed one of the tests.  I could return a boolean that triggers (or not) the next test() but isn't there a simple way to just say
      event.rc = false;
      "STOP EVERYTHING";
      I have the assumption that break; will only stop the test() but still move on to the next test().  Maybe I can return break; so it will be called from the 'master function'?   Is that even possible?
