5 Replies Latest reply on Oct 8, 2014 10:56 AM by A.T. Romano
    PE13 Exporting to FLV
    fdnyfish
      In PE12 I had a bunch of custom FLV export presets that I created.
      In PE13 I don't even see a FLV format to export to
      How do I export to FLV
        • 1. Re: PE13 Exporting to FLV
          A.T. Romano Level 7
          fdnyfish
          Premiere Elements 13 does not offer Adobe Flash Video as one of the choices under Publish+Share/Computer/ (or anywhere else)
          as it did in the past. No more FLV/F4V exports from version 13.
          The feature is still present in Premiere Elements 12, 11, 10, 9, 8, and 4 if the older versions are still available.
          If you have purchased Premiere Elements 13 from Adobe direct, you should be able to get your money back within 30 days
          of purchase.
          Also, there is no more DV or HDV data capture firewire into any Premiere Elements Capture Window in version 13. And,
          the webDVD choice from Publish+Share/ is gone in version 13.
          ATR
          • 2. Re: PE13 Exporting to FLV
            fdnyfish Level 1
            So what format will give me 60fps output?
            • 3. Re: PE13 Exporting to FLV
              A.T. Romano Level 7
              fdnyfish
              Several opportunities with 60 progressive frames per second if not already stated in the name of the preset of a given category
              Publish+Share
              Computer
              AVCHD
              with MP4 file extension
              see under Advanced Button/Video Tab of preset selected to set frame rate
              Publish+Share
              Computer
              QuickTime
              with .MOV file extension
              see under Advanced Button/Video Tab of preset, set video codec such as H.264, then set frame rate
              Publish+Share
              Computer
              Windows Media
              Bottom line, look for the opportunities for your 60 progressive frames per second under the Advanced Button/Video Tab of the preset to
              determine if that export offers the frames per second customization that you want.
              ATR
              • 4. Re: PE13 Exporting to FLV
                fdnyfish Level 1
                Thanks for your help.
                I just did a video to FLV and it was 350mb, same video to MP4 was 1.2gb
                Sent from my iPad3
                • 5. Re: PE13 Exporting to FLV
                  A.T. Romano Level 7
                  fdnyfish
                  Windows Media (Windows Media Video 9 video compression) typically gives the smaller of the file sizes for an export.
                  Have you worked with lowering the bitrate in the Advanced export settings under the Advanced Button/Video tab of the
                  preset to find a good compromise between bitrate, file size, and quality?
                  We will be watching for your results. Any questions or need clarification, please let us know.
                  Thank you.
                  ATR
