2 Replies Latest reply on Oct 8, 2014 1:35 AM by ianloh123
    How to disable/enable other buttons when one is active?
    ianloh123 Level 1
      Hi community!
      I have numerous symbols which animate in when clicked and out when clicked again one at a time. Thx again to vivekuma who helped me materialize this.
      But then i realized i also need to disable the other symbols when one is active and re-enable them when it animates back out like in the sample. I won't hold it against anyone for laughing, but I was trying to combine this bind/unbind with this current var method but it's mostly blind shot after blind shot
      Any help would be greatly appreciated!
        • 1. Re: How to disable/enable other buttons when one is active?
          vivekuma Adobe Employee
          Use the below code:
               1. In compositionReady handler:
                    Add:
                         sym.$(".elf").hide();
                         sym.setVariable("count", 200);
                         this.checkIfActiveSymbol = function(childSym){
                           var bActiveSymbol = sym.getVariable("symName");
                           if(bActiveSymbol && (bActiveSymbol != childSym.name))
                                return false;
                           return true;
                         this.setActiveSymbol = function(childSym) {
                              var bActiveSymbol = sym.setVariable("symName", childSym.name);
                         this.resetActiveSymbol = function() {
                              var bActiveSymbol = sym.setVariable("symName", "");
               2. For click handler for each btn symbol:
                    Replace: use btn1 and btn accordingly for each button symbol.
                         var childSym = sym.getSymbol("btn1");
                         var pos = childSym.getPosition();
                         if(!sym.checkIfActiveSymbol(childSym))
                           return;
                         if (pos < 499) {
                           sym.setActiveSymbol(childSym);
                           sym.getSymbol("btn1").play("1");
                           sym.getSymbol("btn1").$("name").fadeToggle();
                           sym.getSymbol("btn1").$("mailbtn").fadeToggle();
                         if (pos > 501) {
                           sym.resetActiveSymbol();
                           sym.getSymbol("btn1").playReverse(pos);
                         var count = sym.getVariable("count");
                         sym.getSymbol("btn1").getSymbolElement().css({"z-index":count});
                         sym.setVariable("count", count+1);
          hth,
          Vivekuma
          • 2. Re: How to disable/enable other buttons when one is active?
            ianloh123 Level 1
            yup that did the trick, n then some...
            I will learn from this, vivekuma! ur help is not in vain!
