1. Re: IPhone 6+ unsupported screen size?
Colin Holgate Oct 8, 2014 7:57 AM (in response to NAO3133)Have you included the various splash screen sizes?
2. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 8, 2014 10:00 AM (in response to Colin Holgate)Default-667h@2x.png
Yes, These 3 files
3. Re: IPhone 6+ unsupported screen size?
Colin Holgate Oct 8, 2014 10:09 AM (in response to NAO3133)Someone should buy me an iPhone 6 so I can test things!
The file that is used to force devices into full screen is Default-568h@2x.png. I don't yet know if the iPhone 6 files do the same trick, but it may be worth including the iPhone 5 one too, in case it's special in some way.
There may still be an AIR problem where it is relying on using the iPhone 5 splash screen.
BTW, it's odd that you have both portrait and landscape screens.
4. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 8, 2014 11:22 PM (in response to Colin Holgate)I tryed to remove Default-568h@2x.png splash screen. The result was incorrect stage size, but all assets wasn't scale, I had bold black lines at the edges. In last case stage size was incorrect too, but all assets was scale, and i had full screen (without black lines).
Then i tryed to leave Default-568h@2x.png file, but change its size to IPhone 6+ splash screen size by adding red areas to the image, the result was incorrect..again
5. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 9, 2014 12:47 AM (in response to NAO3133)Also I try to rename splash screen file for IPhone 6+ according to Adobe AIR * Application icons and it is Default-736h@3x.png. Remove splash for IPhone 6 (Default-667h@2x.png), and this strange splash Default-Landscape-736h@3x.png. - nothing great!
Also tryed name Default-414w-736h@3x.png - the same result, AIR shows Default@2x.png.
6. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 9, 2014 1:22 AM (in response to NAO3133)I've done it! Yeah!!
The problem was in incorrect splash screen name. The right pattern of name is Default-XXXw-XXXh@3x.png, but width and height was incorrect in my case, because there is "Display zoom" option ON. With this option screen size is 375x667, not 414x736. Renaming of file to Default-375w-667h@3x.png done it's job - correct splash screen, and correct stageWidth/Height !
7. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 9, 2014 3:38 AM (in response to NAO3133)Oh no! I was harry.. The problem is still exist! What about IPhone 6 - all is veri nice! True screen size, true splash screens in both modes (Standart and "Display zoom"), but problem with IPhone 6+ in the both modes:
- In "Display Zoom" mode it shows correct splash screen, but incorrect stage size (1125x2001 is correct, but i have 1334x750)
- In Std mode it shows incorrect splash screen (it takes Default-568h@2x.png, but should take Default-414w-736h@3x.png), and returns incorrect stage size as well.. (correct is 1242x2208, but i have 1472x828)..
8. Re: IPhone 6+ unsupported screen size?
Pait Oct 14, 2014 12:56 PM (in response to NAO3133)According to the release notes at http://labs.adobe.com/downloads/air.html published on Oct 2, 2014, the following issues exist:
[iPhone 6 Plus] Wrong screen size and dpi is returned through the runtime APIs.
[iPad 3 and later]iPhone Launch image(Default@2x.png) appears on iPad if iPhone launch images are packaged along with iPad launch
images.
[iPhone 6 Plus] [Launch Image]: Blank frame appears instead of launch image when only Default@3x.png is packaged with application.
Have these been addressed? If not, what is the status of these problems?
I do not have an iPhone 6 or 6 plus, so I can't test this; but I am eager to publish my app with full support for iPhone 6 and 6 plus.
9. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 14, 2014 10:02 PM (in response to Pait)But I have 15.0.0.302 version of air
10. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 14, 2014 10:05 PM (in response to NAO3133)And in 15.0.0.302 the same known issues
11. Re: IPhone 6+ unsupported screen size?
Graham Smith Oct 15, 2014 3:49 AM (in response to Pait)Hi Pait,
15.0.0.302 seems to solve the issue with incorrect screen size and dpi , my simulator tests seem ok with the default images etc..
The documentation is not getting updated on the builds which is confusing..
Also there was a new SDK released yesterday 10/14/2014 which strangely is the same build as the one from 10/2/2014
both appear to be build 15.0.0.302 ....
confusion ?
12. Re: IPhone 6+ unsupported screen size?
kawikaheftel Oct 28, 2014 12:57 PM (in response to Graham Smith)With the latest AIR SDK (15.0.0.349), I can get iphone 6+ launch screens to be used properly (Default-414w-736h-landscape@3x.png, 2208x1242), but stage.fullScreenWidth/Height give 1472x828, which is 2/3 the expected dimensions or 736x414 at scale factor 2, not 3.
13. Re: IPhone 6+ unsupported screen size?
NAO3133 Oct 28, 2014 11:04 PM (in response to kawikaheftel)This problem still exist in 'known issues' of air sdk.
14. Re: IPhone 6+ unsupported screen size?
kawikaheftel Nov 3, 2014 2:59 PM (in response to NAO3133)Anyone know if iOS 8.1 fixes this issue?
15. Re: IPhone 6+ unsupported screen size?
Colin Holgate Nov 3, 2014 3:06 PM (in response to kawikaheftel)I think not. I've had reports from iPhone 6+ users with AIR apps that are build 349, and still there are startup issues.
