1. Re: Why Am I getting this error: "downloading theme switcher has failed, retrying"
DBarranca Oct 24, 2014 9:31 AM (in response to ronace2)Hi Ronace,
I'm the author of Theme Switcher. I can't say why the CC app tells you that - it does for me too for an old add-on I installed many time ago.
There's an open thread here for removing add ons: https://forums.adobe.com/thread/1585860
Which should be trivial, instead isn't as straightforward as it should be.
Otherwise you can download the installer (instead of let the CC app install it): log in, goes in the product page, "Where to find it" and then "Download / Install your Add-on another way", "Download using Extension Manager"
Mind you, check to have the most recent update of Adobe Extension Manager, it's quite picky as a software.
Hope this helps!
Regards
Davide Barranca
www.davidebarranca.com
www.cs-extensions.com
2. Re: Why Am I getting this error: "downloading theme switcher has failed, retrying"
ronace2 Oct 24, 2014 10:28 AM (in response to DBarranca)Davide:
I did try to use the extension manager to install Theme Switcher. When I pressed the download button I received this error message.
Can you help.
Ronace
3. Re: Why Am I getting this error: "downloading theme switcher has failed, retrying"
K.Woods Oct 27, 2014 3:29 AM (in response to ronace2)Hi Ronace
What version of Extension Manager and Photoshop are you using? Can you upload screenshots to this thread?
