2 Replies Latest reply on Nov 10, 2006 8:32 AM by wushupork
    Flex 2 Tree component vertical scrollbar not updating
    wushupork Level 1
      I am using a Tree component to hold a very large dataset. So instead of loading the whole tree view at once, I only load the first level and make webservice calls every time the user opens a node using the itemOpen event handler. My only problem is that the data shows but the scrollbar does not appear. When I close said folder, and reopen, then the scrollbar appears.
      How should I notify the Tree component that the data has changed and that it should update the scrollbar. I dont want to use ItemRenderer if I dont have to.
      Ive tried these but they dont work:
      m_tree.dataProvider.refresh();
      List(m_tree).invalidateDisplayList();
      List(m_tree).validateNow();
      m_tree.expandItem(m_selectedNode, true, true, true);
