2 Replies Latest reply on Apr 4, 2007 9:09 PM by Newsgroup_User
    onRollOver/Out animation
    abell06
      I have assigned the onRollOver and onRollOut event handlers for a movie clip to enact an alpha animation function on an interval, and it works, but only once.
      http://www.kustedg.com/lincoln.swf
        • 1. Re: onRollOver/Out animation
          Nick Barling Level 1
          You may need to use the clearInterval function after you have finished using the setInterval function.
          You could try adding this:
          clearInterval( intervalID );
          within the mc.EnterSite.onRollOver and mcEnterSite.onRollOut functions.
          regards
          Nick Barling
          www.barkingweb.com
          • 2. Re: onRollOver/Out animation
            Level 7
            > mcEnterSite.onRollOver = function():Void {
            > var nInterval:Number = setInterval(fadeIn, 10);
            > mcEnterSite.onRollOut = function():Void {
            > var nInterval:Number = setInterval(fadeOut, 10);
            > function fadeIn():Void {
            > mcWelcome._alpha++;
            > updateAfterEvent();
            > function fadeOut():Void {
            > mcWelcome._alpha--;
            > updateAfterEvent();
            Nick is right, you need to clear the interval function.
            Basically a setInterval keeps running until the interval-id is cleared. So,
            you would probably be best off using a variable that is in the scope of the
            mcEnterSite... for instance.
            mcEnterSite.intervalId = 0;
            clearInterval(mcEnterSite.intervalId);
            mcEnterSite.intervalId = setInterval(fadeIn, 10);
            mcEnterSite.intervalId = setInterval(fadeOut, 10);
            mcWelcome._alpha ++;
            updateAfterEvent();
            mvWelcome._alpha --;
            updateAfterEvent();
