4 Replies Latest reply on Oct 10, 2014 6:31 AM by Sajeev Sridharan
    reversing selected text or paragraph
    content server
      hi all,
      i have a document that contains the lines reversed (for example, Hello All is written llA olleH), so how can i reverse a selected line and reverse the text inside the line (assuming i select each line before i run the script), and also how can i reverse the whole document without needing to select every single line at a time?
      thanks in advance
        • 1. Re: reversing selected text or paragraph
          Sajeev Sridharan Level 4
          #1: Selected Line or Paragraph
          First select line or paragraph before running the code,
              myString = app.selection[0].contents;
              myString = myString.split("").reverse().join("");
              app.selection[0].contents = myString;
          #2: for whole document
          Try yourself:
          //Logic
          1. loop no. of pages
          2. loop no of textframes
          3. loop no. of lines
          4. then paste the above code
          5. thats it you're done.
          Vandy
          • 2. Re: Re: reversing selected text or paragraph
            BEGINNER_X Level 3
            Hope you are new to scripting, so kindly use the below script.
            With the help of vandy coding,
            var myLines = app.activeDocument.stories.everyItem().lines.everyItem().getElements();
            for(i=0; i<myLines.length; i++)
                if(myLines[i].contents.match(/^\r/) !=null)
                    continue;
                app.select(myLines[i].characters.itemByRange(0, -2));
                alert("select line")
            Regards
            Siraj
            • 3. Re: Re: reversing selected text or paragraph
              content server Level 1
              Dear Sir,
              Thank you for your reply,
              The function ran correctly for couple of pages but we got the following error,
              Kindly, do you have any solution?
              Thank you in advance,
              • 4. Re: Re: Re: reversing selected text or paragraph
                It seems empty textframes in your document, you put try/catch in the code.
                        continue;
                    try{
                    }catch(e){}
                Vandy
