9 Replies Latest reply on Oct 15, 2014 2:05 AM by nilambari
    Cannot see extension installed in extension manager in Indesign CC
    nilambari
      I have created a simple extension for indesign CC.
      Extension manager shows me that extension is successfully installed.
      but i can not see this extension in windows>extensions menu
        • 1. Re: Cannot see extension installed in extension manager in Indesign CC
          Carl Sun Level 4
          Is it a CSXS extension (contains manifest.xml instead of mxi file)? Have you signed it? Normally CSXS extensions must be signed so that ID CC will load it.
          • 2. Re: Cannot see extension installed in extension manager in Indesign CC
            nilambari Level 1
            my manifest file is as follows, i have signed it.
            <?xml version="1.0" encoding="UTF-8"?>
            <ExtensionManifest Version="4.0" ExtensionBundleId="com.example.CatalogGenerator2" ExtensionBundleVersion="1.0.0"
                    ExtensionBundleName="CatalogGenerator2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                <Author>
                    <![CDATA[Nilambari Patil]]>
                </Author>    <ExtensionList>
                    <Extension Id="com.example.CatalogGenerator2.extension1" Version="1.0" />
                </ExtensionList>
                <ExecutionEnvironment>
                    <HostList>
                        <Host Name="IDSN" Version="10.1" />
                    </HostList>
                    <LocaleList>
                        <Locale Code="All" />
                    </LocaleList>
                    <RequiredRuntimeList>
                        <RequiredRuntime Name="CSXS" Version="4.0" />
                    </RequiredRuntimeList>
                </ExecutionEnvironment>
                <DispatchInfoList>
                    <Extension Id="com.example.CatalogGenerator2.extension1">
                        <DispatchInfo >
                            <Resources>
                            <MainPath>./index.html</MainPath>
                            <ScriptPath>./CatalogGenerator2.jsx</ScriptPath>
                            </Resources>
                            <Lifecycle>
                                <AutoVisible>true</AutoVisible>
                            </Lifecycle>
                            <UI>
                                <Type>Panel</Type>
                                <Menu>CatalogGenerator2</Menu>
                                <Geometry>
                                    <Size>
                                        <Height>800</Height>
                                        <Width>1200</Width>
                                    </Size>
                                    <MaxSize>
                                        <Height>2000</Height>
                                        <Width>2000</Width>
                                    </MaxSize>
                                    <MinSize>
                                        <Width>1200</Width>
                                    </MinSize>
                                </Geometry>
                            </UI>
                        </DispatchInfo>
                    </Extension>
                </DispatchInfoList>
            </ExtensionManifest>
            • 3. Re: Cannot see extension installed in extension manager in Indesign CC
              nilambari Level 1
              mxi file is:
              <?xml version="1.0" encoding="UTF-8" standalone="no"?>
              <macromedia-extension id="CatalogGenerator2" name="CatalogGenerator2" requires-restart="false" version="1.0.0">
                <author name="Nilambari Patil"/>
                <description/>
                <license-agreement/>
                <products>
                  <product maxversion="11.1" name="InDesign" version="10.1"/>
                </products>
                <files>
                  <file destination="$indesign/Plug-Ins/Panels" file-type="CSXS" platform="mac" products="InDesign" source="CatalogGenerator2.zxp"/>
                </files>
              </macromedia-extension>
              • 4. Re: Cannot see extension installed in extension manager in Indesign CC
                nilambari Level 1
                nilambari schrieb:
                mxi file is:
                  <description/>
                  <products>
                  </products>
                  <files>
                  </files>
                this might help? i am using Os X 10.9.2
                anybody has any idia? I am really tired of looking for the reasons. When I run the extension from eclipse... run as indesign extension, it works fine. Thats why i think this is something to do with the extension manager CC. I tried to set debug file while installing the extension. gives nothing out.
                • 5. Re: Cannot see extension installed in extension manager in Indesign CC
                  Carl Sun Level 4
                  For ID CC 2014, you should use <RequiredRuntime Name="CSXS" Version="5.0"/> in the manifest.xml.
                  for embedded CEP extensions (file-type="CSXS"), the destination attribute will be ignored. It will always be installed to the CEP folder. You would not find it in "$indesign/Plug-Ins/Panels".
                  • 6. Re: Cannot see extension installed in extension manager in Indesign CC
                    nilambari Level 1
                    ok, when i changed version 5.0, extension got installed without errors. NOTE: I used the eclipse, project>export facility to generate zxp package. attached is the screenshot.Screen Shot 2014-10-12 at 14.46.38.png
                    When i export the zxp extension and try to install it from extension manager cc, it shows installed without any errors.
                    After that i open indesign, Window>Extensions menu, extension is NOT listed there.
                    Second, I try to generate the zxp package with ./ZXPSignCmd command,
                    Nilambaris-MacBook-Air:ccextensionsmac nilambari$ ./ZXPSignCmd -selfSignedCert DE Berlin myCompany CatalogGenerator2 mypass cert.p12
                    Self-signed certificate generated successfully
                    Nilambaris-MacBook-Air:ccextensionsmac nilambari$ ./ZXPSignCmd -sign /Users/nilambari/Projects/indesign/CatalogGenerator2/ CatalogGenerator2.zxp cert.p12 mypass
                    Signed successfully
                    Now when I try to install using extension manager CC generated zxp package, i get following error:
                    Again, extension is not listed in indesign, Window>Extensions menu
                    • 8. Re: Cannot see extension installed in extension manager in Indesign CC
                      nilambari Level 1
                      I am getting frustrated. Is there no solution for this problem? should I throw away all my work along with indesign and extensionmanager cc?????
                      • 9. Re: Cannot see extension installed in extension manager in Indesign CC
                        nilambari Level 1
                        as an example you can use XmpSamplePanel which is also not working
