0 Replies Latest reply on Oct 9, 2014 4:09 AM by JohnDevlon
    [AS/JS][CS5.5/CC2014] How make sure a script always produces the same result ?
    JohnDevlon
      I've been creating Indesign scripts for several years and there is one thing that is still a huge problem when writing a script. How to make sure a script always produces the same result, on all computers.
      The problem is when you create a script, in many cases, it also uses the local user settings when executing it. For example: when you create a script to create a frame and you only define the border thickness, you can have different results on machine A and B. If on machine A, the default front color is set to blue, and on machine B to yellow, the result is not the same frame.
      In many cases configuring each individual property would solve the issue but would take a huge amount of time.
      This could easily be fixed if a script property would be available to ignore local user overrides when executing it. Does anyone know if this feature exists or has a solid solution to fix this problem?
      Thanx
