3 Replies Latest reply on Oct 9, 2014 5:12 AM by Eugene Tyson
    Export vs. Print pdf
    subaG86 Level 1
      Hi Folks,
      Most of them prefer export pdf instead of distiller pdf (ps to pdf) which were discussed in forum also. One of our customer preferred print pdf, but we are facing so many concerns in using print pdf. So we suggested to go for export pdf. But they reason for why we move to export pdf.
      So I'm collecting pros & cons of export vs. print pdf to explain the customer which are listed below. But I need more technical points to explain them. Anyone please list out the points would be really helpful.
      Pros of Export pdf
      Export pdf
      Print pdf
      Can obtain metadata information in exported pdf from InDesign file
      Cannot obtain metadata information from InDesign
      Using InDesign hyperlink, can get hyperlink without broken in pdf
      InDesign hyperlink will be lost
      It supports interactive elements, tagged pdf, layers, etc., used in InDesign
      Interactive elements are thrown away
      No issue in creating pdf using of Mathtype equations
      Problem in creating pdf using of Mathtype equation
      Cons of Export PDF
      Export pdf
      Print pdf
      Cannot create pdf using custom paper size against the document size
      It can create pdf with standard page size.
        • 1. Re: Export vs. Print pdf
          Not sure why you would want that but it could be done via a slug—a 5"x7" page trim could be expanded to 8.5"x11 by adding a 1.75' / 2" slug.
          • 2. Re: Export vs. Print pdf
            Eugene Tyson Adobe Community Professional & MVP
            Dov Isaacs wrote:
            To expand on Bob and Steve's responses, the fact is that “printing” PostScript from InDesign yields PostScript optimized for printing to a live printer and not for production of PDF! Adobe strongly recommends PDF export as opposed to PDF produced by distillation of PostScript!!!!!
            PDF produced by distillation of PostScript loses color management, live transparency, any and all hyperlinks. The resultant PDF may be readily searchable (for text) and may have problems in terms of fonts, especially if you try to subsequently merge such PDF files or perform any Acrobat-based touch up operations.
                      - Dov
            Print To PDF
            https://www.youtube.com/watch?v=gIV0sgdDy8s
            This is great though - when the list is complete let us know - we'll try get it posted as an FAQ.
            Thanks!
            • 3. Re: Export vs. Print pdf
              I don't know why the quote came out like that - but follow the Print PDF link.
