20 Replies Latest reply: Oct 13, 2014 2:23 PM by Max Resnikoff RSS
    How to display image if field value= 'value'
    Max Resnikoff Community Member
      hi,
      how would I go about setting up a table cell which will display a tick if the user has paid, and an x if the user has not yet paid?
      In my database I have the field: payment.
      In the php code I have it set up so that values 0=not paid and 1=paid
      Thank you!
        • 1. Re: How to display image if field value= 'value'
          TwoSuits Community Member
          If I understand you question correctly, you just need a PHP If statement inside the cell. Assuming you have a recordset from your database (if not just change the variable as necessary) it would look something like this:
          <table>
            <tr>
              <td>Invoice Paid:</td>
              <td>
          <?php If ($yourRecodset['payment']==0) { ?>
              <img src="notpaid.jpg"/>
          <?php } else { ?>
              <img src="paid.jpg"/>
          <?php }?>
              </td>
            </tr>
          </table>
          (this assumes that the value can only be 0 or 1. If that is not the case, the Else should be replaced with another If)
          Hope this helps
          Scott
          • 2. Re: How to display image if field value= 'value'
            This is what I have:
            <?php echo $row_clientinfo['paymentstatus']; ?>
            <?php if ($clientinfo['paymentstatus']==0) { ?>
            <img src="../../images/notpaid.png" width="100" height="50" />
            <?php if ($clientinfo['paymentstatus']==4) { ?>
            <img src="../../images/paid.png" width="100" height="50" />
            <?php }}?>
            But it doesnt seem to change if the value is 4.
            Is there something im missing?
            I have the field echoed on the page and it displays the right number, so it isnt something to do with the database.
            • 3. Re: How to display image if field value= 'value'
              You have nested your 'if ($clientinfo['paymentstatus']==4) {' statement inside your 'if ($clientinfo['paymentstatus']==0) {' statement. This means that the condition 4 code will never be seen as that block is only run when the value is 0.
              It should read:
              <?php }?>
              <?php }?>
              Notice the first if statement is closed before the second is reached.
              Scott
              • 4. Re: How to display image if field value= 'value'
                MurraySummers CommunityMVP
                Yes - you have improperly (or inadvertently) nested your conditional tests -
                <?php } ?>
                <?php }?>
                The way you had it written, the only time you would test to see if the value is 4 would be if the value==0 test SUCCEEDED.
                • 5. Re: How to display image if field value= 'value'
                  It is still not working even with your code :/
                  The first set for the not paid code is working. If i change the 0 to 1, it dissapears.
                  The second set doesnt want to work even if i change the equal to:1
                  • 6. Re: How to display image if field value= 'value'
                    osgood_ CommunityMVP
                    Try:
                    <?php } ?>
                    <?php } ?>
                    Should work if you database is set to 0 and 4 respectively/
                    • 7. Re: How to display image if field value= 'value'
                      As the code in your last post stands, the only way the paid image will display is if the value is set to 4. If you want it to work with 0 and 1, where 1 is paid, you need to change
                      to
                      <?php if ($clientinfo['paymentstatus']==1) { ?>
                      • 8. Re: How to display image if field value= 'value'
                        Os, I don't think we are getting through...
                        • 9. Re: How to display image if field value= 'value'
                          Infact you probably only need to test for NOT paid and just print paid if it doesnt meet the condition:
                          <?php }
                          else { ?>
                          <?php } ?>
                          • 10. Re: How to display image if field value= 'value'
                            I hear ya Murray, how you doing? Not seen you around in a while - been busy?
                            • 11. Re: How to display image if field value= 'value'
                              Can you guys (MurraySummers and osgood_) even see my replies? You seem to be repeating my answers. Your last is essentially the same as my original answer to the OP and the others are verbatim code to my second reply (apart from whitespace). If wires are crossing during posting then fine but you guys just seem to not even see/acknowledge my responses?
                              • 12. Re: How to display image if field value= 'value'
                                Sorry I omitted you. Indeed your initial answer is correct.
                                • 13. Re: How to display image if field value= 'value'
                                  Yes - comes in waves, you know?
                                  • 14. Re: How to display image if field value= 'value'
                                    I found the issue:
                                    The variable was the problem.
                                    Instead of this:
                                    <?php } ?>
                                    <?php } ?>
                                    I put this:
                                    <?php $paymentstatus = $row_clientinfo['paymentstatus']; ?>
                                    <?php if ($paymentstatus ==0) { ?>
                                    <?php } ?>
                                    <?php if ($paymentstatus ==1) { ?>
                                    <?php } ?>
                                    • 15. Re: How to display image if field value= 'value'
                                      The variable is not the issue. The top one contains:
                                      whereas the bottom one contains:
                                      The reason it doesn't work is because the top version is looking for a value of  4 which does not exist!
                                      • 16. Re: Re: How to display image if field value= 'value'
                                        I found the issue:
                                        Instead of this:
                                        <?php } ?>
                                        <?php } ?>
                                        I put this:
                                        <?php } ?>
                                        <?php } ?>
                                        Do you see the problem?
                                        • 17. Re: How to display image if field value= 'value'
                                          I found the issue:
                                          Instead of this:
                                          <?php } ?>
                                          <?php } ?>
                                          I put this:
                                          <?php } ?>
                                          <?php } ?>
                                          Sorry TwoSuits - just winding you up - no offense meant - wasn't ignoring your replies, just thought maybe the OP wasn't understanding so just really reinforcing what you wrote.
                                          • 18. Re: How to display image if field value= 'value'
                                            Yeah, same here. All or nothing.
                                            • 19. Re: How to display image if field value= 'value'
                                              I changed it. I only put 4 just to test it to see if it would work with 4!
                                              • 20. Re: Re: How to display image if field value= 'value'
                                                You do realise that the extra variable ($paymentstatus) is not required and that the below code will work exactly the same?
                                                <?php if ($row_clientinfo['paymentstatus'] ==0) { ?>
                                                <?php } ?>
                                                <?php if ($row_clientinfo['paymentstatus'] ==1) { ?>
                                                <?php } ?>
                                                Oh, and by the way - YOU'RE WELCOME!
                                                • 21. Re: Re: How to display image if field value= 'value'
                                                  Well it didnt work with me. As soon as I changed it to a variable it worked.
