0 Replies Latest reply on Oct 10, 2014 9:52 AM by creativejoan0425
    Script UI dialog (Scroll bar with checkbox and editcontent)
    creativejoan0425 Level 1
      Hi expert,
      I have 10 indd files called 1.indd, 2.indd, 3.indd, 4.indd, 5.indd, 6.idd, 7.indd, 8.indd, 9.indd, 10.indd
      and each file have different pages 1.indd (1 page), 2.indd (2 pages), 3.indd (3 pages), 4.indd (4 pages), 5.indd (5 pages), 6.idd (6 pages), 7.indd (7 pages), 8.indd (8 pages), 9.indd (9 pages), 10.indd (10 pages)
      and I open those 10 files and run the script
      For Row1 editcontent, I change 9 to 20 and Row 2 change from 8 to 21
      Only Row 1, 3, 5 Checkbox value is true
      so If I alert all editcontent it should be 20, 21, 7, 6, 5, 4, 3, 2, 10, 1
      but the result is 9, 8, 7, 6, 5, 4, 3, 2, 10,1
      and for the Checkbox value, the result should be true, false, false, true, true, false, false, false, false, false
      but now the result true, false, false, true, true
      And I found that when I change the row 1 9 to 20 and then I use the scrollbar to scroll down and then scroll up , 20 will change back to 9, can make it when I scroll back the result is 20?
      below is my script:
      var DocArray = app.documents.everyItem().name;
      var myPrintFiles =[];
      var myPagesLength =[];
      for (i = 0; i < DocArray.length; i++){
                                      myPrintFiles.push(app.documents.itemByName(DocArray[i]).name);
                                      myPagesLength.push(app.documents.itemByName(DocArray[i]).pages.length);
      var call_codes = {myPrintFiles: myPagesLength};
      var rows = 5, number_of_codes = DocArray.length;
      var w = new Window ("dialog");
      var group = w.add ("group {alignChildren: 'fill'}");
      var panel = group.add ("panel {orientation: 'row', alignChildren: 'top'}");
      var sbar = group.add ("scrollbar {preferredSize: [20, undefined], maxvalue: " + String (number_of_codes-rows) + "}");
      var col1 = panel.add ("group {orientation: 'column', margins: 3}");
      var col2 = panel.add ("group {orientation: 'column', alignChildren: 'fill', preferredSize: [150, undefined]}");
      var fields = {}, start = 0, stop = rows, n = -1, myCheck = {};
               var myPrintFilesJoin =  myPrintFiles.join("\\r");
                          var myPrintFilesSplit =  myPrintFilesJoin.split("\\r");
                                for (j = 0; j < myPrintFilesSplit.length; j++) {
                                         myEachEditContent = myPrintFilesSplit[j];
      for (var i in call_codes){
      ++n;
      if (n >= start && n < stop){
      myCheck[n]  =col1.add ("checkbox", [0, 0, 300, 22], myPrintFilesSplit[j]);
      fields[n] = col2.add ("edittext", undefined, myPagesLength[j].toString().split(","));
      fields[n].label = i; // Add a label property that contains the letter
      fields[n].onChange = function () {call_codes[this.label] = this.text}
      } // When the edittext is changed, update the call_codes object
      sbar.onChanging = function()
      var start = Math.round (this.value); // Round the sbar's value
      var stop = start+rows, n = 0, r = -1;
      //~ for (var i in call_codes)
      n++;
      if (n > start && n <= stop)
      ++r;
      col1.children[r].text = myPrintFilesSplit[j]; // Replace the contents of the statictext
      fields[r].text = myPagesLength[j].toString().split(","); // and the edittext controls
      fields[r].label = i; // and update each edittext's label
      w.show();
      for (j = 0; j < 10; j++) {
      alert(myPagesLength[j].toString().split(","));
      alert(col1.children[j].value);
      Thanks and Best Regards
      Joan
