5 Replies Latest reply: Oct 13, 2014 2:40 AM by Robyn_cpl RSS
    _edgePreload.js
    kgui
      Animation in website is saying
      can not find "xx_edgePreload.js".
      Where can I find "xx_edgePreload.js"?
      Why do we need it?
      None in publish for web.
      None in publish as .oam
        • 1. Re: _edgePreload.js
          vivekuma Adobe Employee
          How are you using the Edge Animation? Give more details.
          • 2. Re: _edgePreload.js
            kgui Community Member
            I'm using the .oam file in combination with Drupal CMS.
            There is NO xx_edgePreload.js located in the .oam file. But I can see that 'edge.5.0.0.min.js', is building a reference to it. But why?
            ...Z?(window.edge_authoring_mode||(m?(k.definePreloader(m),e()):k.load(c+"_edgePreload.js" ,e)), ....
            I've tried it with and without preloader publishing options (immediate | polite).
            • 3. Re: _edgePreload.js
              In line (m ? (k.definePreloader(m),e()) : k.load(c+"_edgePreload.js" ,e) , always definePreloader(m) will be called. There is no concept of _edgePreload.js file in the new Edge for published .oam file.
              I think the Drupal plugin you are using to import edge composition into Drupal project is looking for _edgePreload.js file, which is causing the issue.
              Drupal plugin needs to be updated for the new .oam file.
              hth,
              Vivekuma
              • 4. Re: _edgePreload.js
                So, I understand that .oam animation publishing files are not backwards compatible!?
                Simply adding an empty "_edgePreload.js", only refering to the new situation, would be sufficient for compatibillity reasons, .... .
                But thanks for you answer, I dropped .oam and go for iframes and html.
                • 5. Re: _edgePreload.js
                  Robyn_cpl Community Member
                  Have you updated the new version of Edge Animate?
                  Because if you have the new filing system when publishing and creating Edge projects doesn't have the _edgePreload.js any more its added somewhere else.
