3 Replies Latest reply on Nov 16, 2006 2:02 AM by duckets
    Flash 8 members not reloading correctly
    Level 7
      I have a Flash 8 member that plays ok the first time through. I think use
      the memberUnload function, but when reloading the Flash 8 member and trying
      to play it again, I get errors. Specifically, the Flash Math.Random()
      function starts returning undefined values.
      Is this a Flash 8 problem or does anyone have another suggestion?
      Brian
        • 1. Re: Flash 8 members not reloading correctly
          Level 7
          Director does not play Flash 8. In Flash you should publish your movie as
          Flash 7. Set this in the Publish Settings (i.e., File ==> Publish Settings.
          "Mythic Wave" <brian@ideaslive.com> wrote in message
          news:ehran1$r22$1@forums.macromedia.com...
          > Thanks,
          > Brian
          • 2. Re: Flash 8 members not reloading correctly
            Level 7
            There was an update a few months ago that brought Flash 8 support. You
            need to update Director to the newest version (10.1.1). Then Flash 8
            files will work (as well as a load of other improvements like the
            ability to convert Director image data into Flash bitmaps and use the
            realtime bitmap controls, like drop shadow, blur, etc)
            http://www.adobe.com/support/director/downloads.html
            • 3. Re: Flash 8 members not reloading correctly
              duckets Level 1
              The original poster said: "I have a Flash 8 member that plays ok the first time through" so I'm guessing ithe flash 8 xtra must already be present.
              It sounds more likely to do with the flash movie not initialising properly or something. Perhaps you could try using the lingo command:
              member("your flash member").preload()
              before using the flash movie? (if you haven't tried it already!)
              - Ben
