1 Reply Latest reply on Oct 11, 2014 1:00 AM by Mylenium
    Pre-Comp with Collapse Transformation / Masking / Expression Controls / Etc
    gfx1
      Is there an issue with Pre-Comps and with the Collapse Transformation enabled?
      I have a Pre-comp that has various layer modes in it and in the main comp, the Pre-Comp has collapse transformation enabled to see the layer modes so the text can blend into the background (otherwise the text is just a flat color).
      The pre-comp works completely fine until I add a mask to it or say a expression control and then all of a sudden the collapse transformation stops working and the text loses it's properties.
      This cannot be working as intended...otherwise I can't do any sort of reveal with a mask with anything that is pre-composed and has any sort of blend modes within the pre-comp.
      The pre-comp also loses it's collapse transformation if you even put a expression control on it.
