2 Replies Latest reply on Oct 11, 2014 7:47 AM by Rick Gerard
    Grainy video
    Werlien Level 1
      I have a video attached to a TV screen in AE comp. The TV is moving in 3D space and the video has dissolve transitions. One of the dissolves is grainy fro several frames and them clears up. I welcome any suggestions on how to fix. Let me know if you need more detail.
        • 1. Re: Grainy video
          Provide a screenshot, and project info. Could well be that you are using an effect that doesn't work that well in 8bit or in reverse, you use footage that doesn't look too good in 16bpc or 32bpc.
          • 2. Re: Grainy video
            By dissolve do you mean you used an effect, animated opacity, or the dissolve is in the original video? I'd rather know the answer to that question before I make a guess, but if you the transition effect Block Dissolve then this is normal.
