2 Replies Latest reply on Oct 12, 2014 9:43 AM by Henry Thuan
    Can you help with "LinkExport_Pro1a_EN"?
    Henry Thuan
      Found "LinkExport_Pro1a_EN" (Thanks to its author!), It ran but always ended with message "Javascript Error 45, invalid object, line.... The text outputs are sometimes complete, other times fell short. Any ideas? Thanks.
        • 1. Re: Can you help with "LinkExport_Pro1a_EN"?
          Jump_Over Level 5
          ...ended with message "Javascript Error 45, invalid object, line....
          place entire error message. Most important part is cut
          Did you modify this code or it is original version?
          Jarek
          • 2. Re: Can you help with "LinkExport_Pro1a_EN"?
            Henry Thuan Level 1
            Thank you, Jump_Over
            Complete message "Javascript Error   Error Number 45   Error String: Object Invalid   Engine: Main     File:C\Programfiles\\\\
            Source:  theFiles[myCounter].parent.geometricBounds; Interpreter: CS (2.0)
            Now that you asked for whole message, looked closer (earlier always assumed I can't never understand it, only experts who know what Error 45 means may).
            Its last phrase on INTERPRETER reminds me I used to work with CS2, but now with Indd CC
            Edited that part of the script to be:
            // Set to 2.0 scripting object model
            // app.scriptPreferences.version = 2.0;
            #target "indesign-9.064"
            and IT WORKED FINE. Thanks
