8 Replies Latest reply on Apr 17, 2007 6:23 AM by jfalberg
    Loading random images in intervals
    jfalberg
      I am very new to doing ActionScripts and I want to create an applet which reads from an XML and builds an array of the URL for images, then loads the images in a repeat with about 5 second intervals without the use of any buttons. Here's what I have in my actionscript coding, but what does not seem to work is the ability to switch images in a loop. How can I do that?
        • 1. Loading random images in intervals
          jfalberg Level 1
          hello?
          I figured how to do setInterval but am still still stuck on why I cannot replace images.
          Help!
          • 2. Re: Loading random images in intervals
            The Feldkircher Level 2
            Hi
            Can you post a sample of your XML structure, I can see how your loading your image into your mc.
            I think your problem is your creating a new emptymovieclip 'mc' on every pass, and not loading it one pre-defined img_holder!!!!
            Hope it helps
            • 3. Re: Loading random images in intervals
              jfalberg Level 1
              Thanks for the reply.
              Here's a sample of my XML file as it is basically used to create a single array to contain a relative URL of the image to use:
              <?xml version="1.0" encoding="UTF-8"?>
              <imglist>
              <imgfile>images/N85735_101_12.jpg</imgfile>
              <imgfile>images/N86579_101_12.jpg</imgfile>
              <imgfile>images/N86712_101_12.jpg</imgfile>
              <imgfile>images/N86716_101_12.jpg</imgfile>
              </imglist>
              • 4. Re: Loading random images in intervals
                OK - I have created a new .fla that will do what you want.
                Send me an email address and I can send you the file.
                Just mention that the randomization of images may need playing around with, but the more images you have the less likely you will have repetition so close together.
                Ciao for Now
                • 5. Loading random images in intervals
                  OK! to place multiples of the same Symbol on the Stage we need to change the instance name slightly for each one.
                  The easiest way to do this is to place the amount (multiple) into a for...loop. In your case you need four items
                  for(c=0;c<=3;c++)
                  var mc = home.attachMovie("imageContainer", "imageContainer" + c, 1+c);
                  mc._x = ?; // you will need to calculate x for each symbol
                  mc._y = ?; // also with y
                  So basically we have created imageContainer0 to imageContainer3 and using c+1 we have them on different depths.
                  Now all you have to do is reference each one in your loadImage loop.
                  Hope it helps
                  • 6. Loading random images in intervals
                    jfalberg Level 1
                    Thanks for your assistance The FeldKircher as I'm trying to understand the following line of code:
                    So if I understand correctly, the first parameter will be the object name in the library, and the 2nd (imageContainer0, etc...) is each instance?
                    Edit: I think I finally got it to work as desired. Just a few things I'll need to cleanup in my coding. While the XML file I've been using has been simple enough to only contain the image URL, I am thinking later on I may want to expand on it such as having certain text and/or perhaps a linkable URL so that each image can have a link to click to.
                    • 7. Re: Loading random images in intervals
                      Hi
                      No Problem, glad to help.
                      You got it, imageContainer is the Linkeage identifier of the library MovieClip, imageContainer0..etc is the Instance name.
                      Extending what you have is a good idea, do you intend to open the image in its own window or on Stage?.
                      • 8. Re: Loading random images in intervals
                        jfalberg Level 1
                        I believe this will be as far as I'll go with this particular project though I may revisit at some point later on. One thing I do notice is that it saves the resource files to the Temporary Internet Files folder so I may want to limit the image rotation to a certain amount. The images I am using are relatively small (150 x 150 in pixels) so hopefully that won't be too much of a problem if I limit it to say the first 80-100 images out of a possible many.
