10 Replies Latest reply on Mar 2, 2017 5:33 PM by luv705one
    How can I create a curves adjustment layer in JavaScript?
    gregbenz Level 1
      I've been trying a few different approaches along the lines of:
      var newLayer = activeDocument.artLayers.add(); // Create a new ArtLayer object
      newLayer.name = "MyLayer"; // name it for later reference
      app.activeDocument.artLayers.getByName("MyLayer").kind=LayerKind.CURVES
      When I do, I get an error that I can only change the layer's kind to text or normal.  Anyone know how to create a new curves adjustment layer via script?
        • 1. Re: How can I create a curves adjustment layer in JavaScript?
          c.pfaffenbichler Level 9
          Have you tried to see if ScriptingListener.plugin records code for this?
          • 2. Re: How can I create a curves adjustment layer in JavaScript?
            gregbenz Level 1
            SciptListener does work, but isn't clean.  Is there not a way to code it?  Part of what I'm trying to do is just get a handle on curves using JavaScript in Photoshop.  Even with ScriptListener, I seem unable to adjust the curve once I create it.
            • 3. Re: How can I create a curves adjustment layer in JavaScript?
              That statement does not make a lot of sense.
              A common practice to get more readable code is to pack the AM code into functions.
              Do you mean change the settings or raise the dialog?
              • 4. Re: How can I create a curves adjustment layer in JavaScript?
                Greg Benz
                Agree, functions are an option.  Maybe I just need to get used to that.
                For the curves adjustments, I'm trying to set multiple points on a curve.  Having trouble both with ScriptListener and writing JavaScript.
                • 6. Re: How can I create a curves adjustment layer in JavaScript?
                  gregbenz Level 1
                  Not sure I'm tracking here... I'm looking to adjust the overall luminosity, not individual RGB curves.
                  • 7. Re: How can I create a curves adjustment layer in JavaScript?
                    So change the code to affect the composite channel or use the same values for all three channels.
                    • 8. Re: How can I create a curves adjustment layer in JavaScript?
                      jugenjury Level 2
                      I have a script I think will do what you want. You set 2 color picker spots (first one is the "good" color, second is the "bad" color). The script creates a curves adjustment layer and alters the curves to match the colors at those 2 spots...it will adjust to make the color at spot 2 the same as the color at spot 1. You also can set the average area to sample from. It's a fairly big script but I can post it if you want.
                      • 9. Re: How can I create a curves adjustment layer in JavaScript?
                        jugenjury Level 2
                        Here is the script I use. The way it works is you choose 2 spots with the color picker tool. Spot 1 is the "good" color and spot 2 is the "bad" color. The script will attempt to use a curves adjustment layer to match the area at spot to with the area at spot one. The variable Avg will give you a radius around each point to average the colors at the spots chosen.
                        Start with the raster (or smart object) layer selected that contains the colors to compare. Choose your 2 spots. Run the script. This will create a curves adjustment layer above your start layer named similar to your start layer with a number after it. It will also invert the mask on the curves layer. You then unmask the area you wish to "fix" by painting with white on the mask at that area. It's best to use a low flow and/or low opacity and a soft brush in order to blend in around the edges of where you unmask.
                        What it does is first compares all the channels (red, green, and blue) for each spot and determines the best curves adjustment with the composite channel (all 3 channels combined...this is the main curves you see when you first create a curves adjustment layer). It will then recheck and fine tune any hue/saturation differences by slightly adjusting each channel individually. Let me know if you have any questions.
                        #target Photoshop
                        var startRulerUnits = app.preferences.rulerUnits;
                        var startTypeUnits = app.preferences.typeUnits ;
                        var startDisplayDialogs = app.displayDialogs;
                        app.preferences.rulerUnits = Units.PIXELS;
                        app.preferences.typeUnits = TypeUnits.PIXELS;
                        app.displayDialogs = DialogModes.NO;
                        doc=app.activeDocument;
                        var colorRefin=new SolidColor;
                        var colorRefout=new SolidColor;
                        R=new Array;
                        G=new Array;
                        B=new Array;
                        var dialogMode=DialogModes.NO;
                        Avg=20;
                        size=[0+" px",0+" px",doc.width,doc.height];
                        function arrayComp(array1,array2) {
                            if (array1.length != array2.length) return false;
                            i=array1.length-1;
                            while {
                                if (array1[i] != array2[i]) return false;
                                i--;
                            return true;
                        // Name the layer with the next higher number available for the given name.
                        function nameLayer(fromLayer) {
                            var rlayer=new String(fromLayer.name);
                            l=rlayer.length-1;
                            while (l>0) {
                                if (isNaN(rlayer[l]) || rlayer[l]==" ") break;
                                l--;
                            l++;
                            baseLayer=new String(rlayer.substring(0,l));
                            nl=parseInt(rlayer.substring(l,rlayer.length)) +1;
                            if (isNaN(nl)) {
                                l++;
                                baseLayer=baseLayer+" ";
                                nl=1;
                            while (isLayer(baseLayer+nl)) nl++;
                            return baseLayer+nl;
                        // Check to see if a layer by "name" exists.
                        function isLayer(name) {
                            i=doc.layers.length-1;
                            while ((i+1)>0) {
                                if (doc.layers[i].name == name) return true;
                                i--;
                            return false;
                        //Get the layer number of a layer
                        function getLayerNum(reflay) {
                            i=0;
                            while (doc.layers[i]) {
                                if (doc.layers[i] == reflay) return i;
                                else i++;
                        // Find the appropriate Rasterized layer in the stack.
                        function getRasterLayer(num) {
                            i=num;
                                if ((doc.layers[i].kind == LayerKind.NORMAL || doc.layers[i].kind == LayerKind.SMARTOBJECT) && arrayComp(doc.layers[i].bounds,size)) return doc.layers[i];
                                else i++;
                                if (i>doc.layers.length-1) return doc.layers[doc.layers.length-1];
                            return -1;
                        // Set up the new curves layer in the stack and rename it.
                        function setColorLayer(st,colLayer) {
                            i=st;
                            l=1;
                            refLay=null;
                                if (doc.layers[i].name.substring(0,13)=="Color Adj") {
                                    refLay=doc.layers[i];
                                    l++;
                                i--;
                                if (i<0) break;
                            if (refLay) {
                                colLayer.name="Color Adj " + l;
                                colLayer.move(refLay,ElementPlacement.PLACEBEFORE);
                            else colLayer.name="Color Adj 1";
                        function hasSelection(doc) {
                            if(doc == undefined) doc = activeDocument;
                            var res = false;
                            var as = doc.activeHistoryState;
                            doc.selection.deselect();
                            if (as != doc.activeHistoryState) {
                                res = true;
                                doc.activeHistoryState = as;
                            return res;
                        // Average the colors if needed
                        function getSelectionColor(s,A){
                                if (!s) { s=1;}
                                if (!A) {A=1;}
                                CP=doc.colorSamplers;
                                s=s-1;
                                sampleSize=A;
                                r=((A-1)/2);
                                x=Math.round(CP[s].position[0]-r);
                                y=Math.round(CP[s].position[1]-r);
                                doc.selection.select([[x, y], [x+sampleSize, y], [x+sampleSize, y+sampleSize], [x, y+sampleSize]], SelectionType.REPLACE, 0, false);
                                if (doc.activeLayer.kind!=LayerKind.NORMAL) {
                                    doc.selection.copy();
                                    templay=doc.paste(true);
                                    templay.applyAverage();
                                    var sColor = new SolidColor();
                                    sColor=CP[s].color;
                                    templay.remove();
                                else {
                                    doc.activeLayer.applyAverage();
                                    sColor=CP[s].color;
                                    executeAction( charIDToTypeID('undo'), undefined, DialogModes.NO );
                                return sColor;
                        // Read from the .ini file if present
                        function readini() {
                            var SCRIPTS_FOLDER = new Folder(app.path + '/' + localize("$$$/ScriptingSupport/InstalledScripts=Presets/Scripts"));
                            ini=new File([SCRIPTS_FOLDER + "/TMAColorAdjust.ini"]);
                            if (ini.created) {
                                $.evalFile(ini);
                                return true;
                            ini.close();
                        // Make Curves Adjustment Layer
                        function addCurve() {
                            var desc1 = new ActionDescriptor();
                            var ref1 = new ActionReference();
                            ref1.putClass(PSClass.AdjustmentLayer);
                            desc1.putReference(PSString.Null, ref1);
                            var desc2 = new ActionDescriptor();
                            var desc3 = new ActionDescriptor();
                            desc3.putEnumerated(PSString.presetKind, PSString.presetKindType, PSString.presetKindDefault);
                            desc2.putObject(PSKey.Type, PSClass.Curves, desc3);
                            desc1.putObject(PSKey.Using, PSClass.AdjustmentLayer, desc2);
                            executeAction(PSEvent.Make, desc1, DialogModes.NO);
                        // Set Curves Adjustment Layer
                        function setCurve(IN,OUT,chan) {
                            switch (chan) {
                                case 0:
                                case null:
                                curveChan=PSEnum.Composite;
                                break;
                                case 1:
                                curveChan=PSEnum.Red;
                                break;
                                case 2:
                                curveChan=PSEnum.Green;
                                break;
                                case 3:
                                curveChan=PSEnum.Blue;
                                break;
                            ref1.putEnumerated(PSClass.AdjustmentLayer, PSType.Ordinal, PSEnum.Target);
                            var list1 = new ActionList();
                            var ref2 = new ActionReference();
                            ref2.putEnumerated(PSClass.Channel, PSClass.Channel, curveChan);
                            desc3.putReference(PSClass.Channel, ref2);
                            var list2 = new ActionList();
                            var desc4 = new ActionDescriptor();
                            desc4.putDouble(PSKey.Horizontal, 0);
                            desc4.putDouble(PSKey.Vertical, 0);
                            list2.putObject(PSClass.Point, desc4);
                            var desc5 = new ActionDescriptor();
                            desc5.putDouble(PSKey.Horizontal, IN);
                            desc5.putDouble(PSKey.Vertical, OUT);
                            list2.putObject(PSClass.Point, desc5);
                            var desc6 = new ActionDescriptor();
                            desc6.putDouble(PSKey.Horizontal, 255);
                            desc6.putDouble(PSKey.Vertical, 255);
                            list2.putObject(PSClass.Point, desc6);
                            desc3.putList(PSKey.Curve, list2);
                            list1.putObject(PSClass.CurvesAdjustment, desc3);
                            desc2.putList(PSKey.Adjustment, list1);
                            desc1.putObject(PSKey.To, PSClass.Curves, desc2);
                            executeAction(PSEvent.Set, desc1, dialogMode);
                        function setSwatch() {
                            ref1.putProperty(PSClass.Color, PSKey.Colors);
                            executeAction(PSEvent.Reset, desc1, DialogModes.NO);
                        //    executeAction(PSEvent.Exchange, desc1, DialogModes.NO);
                        function pickBrush() {
                            ref1.putClass(PSClass.PaintbrushTool);
                            executeAction(PSEvent.Select, desc1, DialogModes.NO);
                        function clipPoint(cpin,cpout) {
                            if (cpin==cpout) return [128,128];
                            if (cpin>cpout) {
                                if (cpin > 128) return [cpout,Math.max(Math.min((cpout*3-cpin*2),255),0)];
                                else return [cpout,Math.max(Math.min((cpout*2-cpin),255),0)];
                            if (cpout>cpin) {
                                if (cpin<128) return [cpout,Math.max(Math.min((cpin*3-cpout*2),255),0)];
                                else return [cpout,Math.max(Math.min((cpin*2-cpout2),255),0)];
                        function loadVars() {
                            PSClass = function() {};
                            PSEnum = function() {};
                            PSEvent = function() {};
                            PSForm = function() {};
                            PSKey = function() {};
                            PSType = function() {};
                            PSUnit = function() {};
                            PSString = function() {};
                          PSClass.AdjustmentLayer = cTID('AdjL');
                          PSClass.Channel = cTID('Chnl');
                          PSClass.Color = cTID('Clr ');
                          PSClass.Curves = cTID('Crvs');
                          PSClass.CurvesAdjustment = cTID('CrvA');
                          PSClass.PaintbrushTool = cTID('PbTl');
                          PSClass.Point = cTID('Pnt ');
                          PSEnum.Blue = cTID('Bl  ');
                          PSEnum.Composite = cTID('Cmps');
                          PSEnum.Green = cTID('Grn ');
                          PSEnum.Red = cTID('Rd  ');
                          PSEnum.Target = cTID('Trgt');
                          PSEvent.Invert = cTID('Invr');
                          PSEvent.Exchange = cTID('Exch');
                          PSEvent.Make = cTID('Mk  ');
                          PSEvent.Reset = cTID('Rset');
                          PSEvent.Select = cTID('slct');
                          PSEvent.Set = cTID('setd');
                          PSKey.Adjustment = cTID('Adjs');
                          PSKey.Colors = cTID('Clrs');
                          PSKey.Curve = cTID('Crv ');
                          PSKey.Horizontal = cTID('Hrzn');
                          PSKey.To = cTID('T   ');
                          PSKey.Type = cTID('Type');
                          PSKey.Using = cTID('Usng');
                          PSKey.Vertical = cTID('Vrtc');
                          PSString.Null = sTID('null');
                          PSString.presetKind = sTID('presetKind');
                          PSString.presetKindCustom = sTID('presetKindCustom');
                          PSString.presetKindDefault = sTID('presetKindDefault');
                          PSString.presetKindType = sTID('presetKindType');
                          PSType.Ordinal = cTID('Ordn');
                        cTID = function(s) { return app.charIDToTypeID(s); };
                        sTID = function(s) { return app.stringIDToTypeID(s); };
                        if (doc.colorSamplers.length ==2) {
                            if (hasSelection(doc)) {
                                sel=doc.selection.bounds;
                                Sel=new Array([sel[0],sel[1]],[sel[2],sel[1]],[sel[2],sel[3]],[sel[0],sel[3]]);
                                Area=parseInt(((sel[3]-sel[1]+sel[2]-sel[0])/2));
                            else sel=false;
                            actLayer=doc.activeLayer;
                        //    if (actLayer.isBackgroundLayer ) alert("Background Layer");
                            if (doc.layers.length < 2) actLayer=actLayer.duplicate();
                            startLayer=getRasterLayer(getLayerNum(doc.activeLayer));
                            doc.activeLayer=startLayer;
                            // Check to see if a selection was made. If so, we want to average
                            //  the color for that size area but centered on the Color Picker spot.
                            // Or, alternately, set Avg (above) to a specific value you wish to use in case of no selection.
                            // If not, just use the color from the Color Picker itself.
                            if (sel) {
                                colorRefin=getSelectionColor(2,Area);
                                colorRefout=getSelectionColor(1,Area);
                            else if (Avg>1) {
                                Area=Avg;
                            else {
                                colorRefin=doc.colorSamplers[1].color; //Color Sampler #2=Bad Color
                                colorRefout=doc.colorSamplers[0].color; //Color Sampler #1=Good Color
                            // Reselect original selection in case we want to re-run this with the same average area.
                            Rin=Math.round(colorRefin.rgb.red);
                            Gin=Math.round(colorRefin.rgb.green);
                            Bin=Math.round(colorRefin.rgb.blue);
                            Rout=Math.round(colorRefout.rgb.red);
                            Gout=Math.round(colorRefout.rgb.green);
                            Bout=Math.round(colorRefout.rgb.blue);
                            loadVars();
                            curveLayer=addCurve();
                            if ((Rin+Gin+Bin)>(Rout+Gout+Bout)) {
                                if (Rin>Gin) {
                                    if (Gin>Bin) {
                                        compIn=Bin;
                                        compOut=Bout;
                                    else {
                                        compIn=Gin;
                                        compOut=Gout;
                                else {
                                    if (Rin>Bin) {
                                        compIn=Bin;
                                        compOut=Bout;
                                    else {
                                        compIn=Rin;
                                        compOut=Rout;
                            else {
                                if (Rin<Gin) {
                                    if (Gin<Bin) {
                                        compIn=Bin;
                                        compOut=Bout;
                                    else {
                                        compIn=Gin;
                                        compOut=Gout;
                                else {
                                    if (Rin<Bin) {
                                        compIn=Bin;
                                        compOut=Bout;
                                    else {
                                        compIn=Rin;
                                        compOut=Rout;
                            setCurve(compIn,compOut,0);
                            newLayer=doc.activeLayer;
                            newLayer.name=nameLayer(actLayer);
                            newLayer.move(actLayer,ElementPlacement.PLACEBEFORE);
                            doc.activeLayer=newLayer;
                            setCurve(Rin,Rout,1);
                            setCurve(Gin,Gout,2);
                            setCurve(Bin,Bout,3);
                            Rdif=Math.round(colorRefin.rgb.red)-Rin;
                            Gdif=Math.round(colorRefin.rgb.green)-Gin;
                            Bdif=Math.round(colorRefin.rgb.blue)-Bin;
                            Rw=Rout-Rin;
                            Gw=Gout-Gin;
                            Bw=Bout-Bin;
                            if (Rdif!=0) {
                                Rin=(Rout-(Rw*Rw/Rdif));
                                setCurve(Rin?Rin:Rout,Rout,1);
                            if (Gdif!=0) {
                                Gin=(Gout-(Gw*Gw/Gdif));
                                setCurve(Gin?Gin:Gout,Gout,2);
                            if (Bdif!=0) {
                                Bin=(Bout-(Bw*Bw/Bdif));
                                setCurve(Bin?Bin:Bout,Bout,3);
                            setSwatch();
                            pickBrush();
                            executeAction(PSEvent.Invert, undefined, DialogModes.NO);
                        //    if (sel) doc.selection.select(Sel);
                        else alert("You must choose 2 spots using the color picker tool");
                        • 10. Re: How can I create a curves adjustment layer in JavaScript?
                          luv705one
                          I tried this and it errors out on the while { take on line 24.
                          I think there supposed to be () ....( but I can't figure out what goes in the parentheses).
                          Does this run on your machine?
