3 Replies Latest reply on Jun 29, 2007 11:00 AM by cf_dev2
    Element Undifined in form error.
    baskark
      I have the following code:
      There will be as many hidden fields as the number of rows retrieved by the query "getCities". Each is distinguished with the value of level_detail_uid for each loop.
      city.cfm
      <html>
      <head>
      <title>Update </title>
      <script language="JavaScript">
      function delete_city(level_detail_uid,city_id ,cnam)
      if ( confirm("Are you sure to delete the pricing-information for " + city_id + " ?") )
      window.location = 'city_pricing_display.cfm?delete_level_detail_uid=' + level_detail_uid +
      '&delete_city_name=' + city_id + '&del_cnam=' + cnam;
      <cfif isDefined("delete_level_detail_uid") and delete_level_detail_uid is NOT "">
      <cfoutput> #del_cnam#</cfoutput>
      <cftransaction>
      </cfquery>
      </cfif>
      </cftransaction>
      </cfif>
      <form method="POST" name="city_details" action="city_update_pop.cfm">
      <table border="0" cellspacing="0" cellpadding="0" width="100%">
      <tr>
      <td>
      <cfquery name="getCities" datasource="#application.alcdatasource#">
      SELECT city_name, dtl.level_detail_uid,
      FROM alc_pricing_level_details dtl, alc_city c, alc_detail_provider prvdr
      WHERE level_desc_uid = #level_desc_uid#
      AND dtl.level_detail = c.city_id(+)
      AND prvdr.level_detail_uid = dtl.level_detail_uid
      ORDER BY upper(city_name)
      </cfquery>
      <cfloop query="getCities">
      <cfoutput>
      <input type="hidden" name="cityname_#level_detail_uid#" value="#getCities_city_name#">
      </cfoutput>
      <td>
      <a href="JavaScript:delete_city('#level_detail_uid#','#city_id#','#form.cityname_#level_deta il_uid##')" class="PageInnerNavigationHeadingSmall">Delete City</a>
      </td>
      </table>
      </body>
      </form>
      </html>
      Suppose the level_detail_uid is 12345.
      After executing this it says
      "element cityname_ is undefined in form
      Please kindly help.....
      Thanking in advance....
      Regards,
      Aswathy.
        • 1. Re: Element Undifined in form error.
          jdeline Level 1
          Post the actual error message and the lines of code it refers to.
          • 2. Re: Element Undifined in form error.
            cf_matt Level 1
            I think it must be this line
            <a href="JavaScript:delete_city('#level_detail_uid#','#city_id#', '#form.cityname_#level_detail_uid##')" class="PageInnerNavigationHeadingSmall">Delete City</a>
            It might have to be #evaluate("form.cityname_" & level_detail_uid)#
            although i can see a number of problems in this code.
            • 3. Re: Element Undifined in form error.
              cf_dev2 Level 1
              I agree with cf_matt. There are several problems with the code. The field form.cityname_#level_detail_uid# won't exist when the form is first loaded. So you can't use it in your link unless you define a default value first
              <a href="JavaScript:delete_city('#level_detail_uid#','#city_id#','#form.cityname_#level_deta il_uid##')" >...</a>
              Also, the syntax to retreive the value is wrong. Assuming the variable is defined, try using array notation
              #form["cityname_#level_detail_uid#"]#
