1 Reply Latest reply on Oct 14, 2014 5:31 PM by Sean_Wilson
    Wait or hold
    H.F. Duijndam Level 1
      Hi there
      I am using this code, and i want the movie to hold for 2 sec before it goes further
      who can help me with this?
      tia
      Herman
      on mouseDown
        cursor 4
        put empty into field "FieldCh36"
        Put field "field 19" into field "FieldCh36"
        Put empty into field "field 19"
        cursor 0
        if field "FieldCh36" = "vogelnestjestang" then
          put empty into field "field 19"
          sprite(20).visible = true
          -- Here i want to wait voor 2 sec how can i do this?
          go next
        end if
        if field "FieldCh36" <> "vogelnestjestang" then
          put field "FieldCh36" into field "field 19"
          sprite(21).visible = true
        end if
      end
        • 1. Re: Wait or hold
          Sean_Wilson Adobe Community Professional
          You have a couple of options.
          The quick-and-dirty (and not recommended) solution is to tie up your processor doing nothing for 2 seconds:
          tMillis = the milliseconds + 2000
          repeat while the milliseconds < tMillis
            nothing
          end repeat
          A better solution is to use a timeout object and a callback handler (I can't tell if the code you posted is in a behavior script attached to a sprite or in a movie script):
          -- yadda yadda
          t = timeout().new("goNext", 2000, #mNavigate, 0)
          -- add this new handler to a movie script
          on mNavigate padParameter, aTimeout
            if ilk(aTimeout, #timeout) then aTimeout.forget()
            go next
          end
