1. Re: scaling distance between objects (ill CC)
pattern_bobster Oct 14, 2014 6:41 AM (in response to pattern_bobster)I am greatful for all the help i can get!
greets,
erich
2. Re: scaling distance between objects (ill CC)
Monika Gause Oct 14, 2014 7:00 AM (in response to pattern_bobster)You need to do the math and do this in two steps:
First scale them up, also increasing the size. Then scale them down again using Object > Transform > Transform each, this time only scaling the objects. They need to be ungrouped for this step.
3. Re: scaling distance between objects (ill CC)
Jacob Bugge Oct 14, 2014 7:27 AM (in response to pattern_bobster)bobster,
In this case, you may create the pattern in a quite different way and just scale once according to need:
1) Create a square of arbitrary size with no fill and a Stroke Weight equalling the dot size;
2) Object>Path>Average, with Both ticked;
Now you have the first dot;
3) Create the pattern by copying, maybe through the Effect option followed by expanding;
4) Just scale up as desired.
This is most relevant in connexion with (possibly) repeated different scalings.
4. Re: scaling distance between objects (ill CC)
pattern_bobster Oct 14, 2014 10:33 PM (in response to Monika Gause)I completely forgot to ungroup my objects...no wonder it didn't work as it should have
Thanks alot!
