2 Replies Latest reply on Oct 15, 2014 1:20 AM by Jump_Over
    "Error Number 2" in Indesign CS3 script
    Collin de Visser
      Hello,,
      Everytime I run a script in  Indesign CS3 I get the following error:
      "Javascript error!
      Error Number: 2
      Error String: User cancelled this action.
      Line: 103
      Source: TF.place(aFile);"
      100oldRuler = myDoc.viewPreferences.rulerOrigin
      101myDoc.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
      102var TF = addPageWithTF(masterPage);
      103TF.place(aFile);
      104var myPara = TF.paragraphs[0];
      Who can help me and see what's wrong?
      It's supposed to import a list of word-documents, but doesn't.
      Thanks in advance,
      Collin
        • 1. Re: "Error Number 2" in Indesign CS3 script
          csm_phil Level 4
          Hi Collin de Visser,
          Try the below codes.
          Please insert the below line after the 101 lines.
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
          End of your code insert this line.
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
          thx,
          csm_phil
          • 2. Re: "Error Number 2" in Indesign CS3 script
            Jump_Over Level 5
            So, can you run a script in other Indesign versions with no errors?
            102 var TF = addPageWithTF(masterPage);
            103 TF.place(aFile);
            Both lines use variables created outside of part of code you pasted here. Did you check their values (i.e. - debug breakpoint set and "DataViewer" opened in ESTK)
            What is the result of function addPageWithTF() - a page or a textFrame?
            Moreover:
            You can add a second parameter to method TF.place(file, showingOptions), like:
            TF.place(aFile, false);
            Jarek
