3 Replies Latest reply on May 7, 2006 7:06 AM by Newsgroup_User
    External Style Sheets and new items
    Level 7
      Hello,
      I'm learning DW8 and I've created a site and created my index.html.
      When I create a new layer or change the page properties (or create any
      new object it seems) I was expecting it to put the associated CSS code
      into the external CSS file. Instead DW8 keeps putting the style code
      directly into the index.html file.
      I've manually moved everything to the external CSS file and it "works"
      properly when previewing in DW or browsers. The page has the
      appropriate link to the external CSS file but DW8 still keeps adding
      new CSS code to the index.html file instead of the external CSS file
      I've defined. Is this just how DW8 works or have I done something
      wrong? If so what? How can I correct it?
      Any help would be greatly appreciated.
      Thanks!
      Kelly E Major
        • 1. Re: External Style Sheets and new items
          Level 7
          Can anyone tell me if this is expected behavior or what the problem
          might be?
          Again, any help would be greatly appreciated.
          Thanks!
          Kelly E Major
          On Sat, 06 May 2006 17:54:59 -0500, Kelly E Major
          <k.e.m.a.j.o.r.NODOTS@cox.net> wrote:
          >Hello,
          >Thanks!
          >Kelly E Major
          • 2. Re: External Style Sheets and new items
            Level 7
            It's expected behavior.
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.dreamweavermx-templates.com - Template Triage!
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
            "Kelly E Major" <k.e.m.a.j.o.r.NODOTS@cox.net> wrote in message
            news:kqor52dn2qpdappirku4vupokms5ufoqsd@4ax.com...
            > might be?
            > Thanks!
            > Kelly E Major
            >>Hello,
            >>Thanks!
            >>Kelly E Major
            • 3. Re: External Style Sheets and new items
              Level 7
              > might be?
              > Thanks!
              > Kelly E Major
              >> Hello,
              >> Thanks!
              >> Kelly E Major
              I could be wrong, since I always edit my CSS files in Topstyle (I have
              it selected as my CSS editor in DW), but AFAIK DW will create styles
              directly in your document whenever you change things via the Property
              Inspector. It's best to get into the habit of making your changes
              directly in the style sheet (and be sure the changes get saved). Hope
              this helps.
              Bonnie in California
              kroko at
              sbcglobal dot net
              http://www.theanimalrescuesite.com/cgi-bin/WebObjects/CTDSites.woa
