0 Replies Latest reply on Oct 14, 2014 10:50 AM by chris.campbell
    10/14/2014 - Release - Flash Player 15
    chris.campbell Adobe Employee
      The next version of Flash Player is available for immediate download.  In today's release we've updated Flash Player with important security updates and bug fixes.  We recommend users update to the latest version.
      Security update details can be found here: Security Bulletin (APSB14-22)
      New Features for Flash Player 15:
      • Relaxing Stage3D Render Target Clear
      In previous versions of Stage3D, after switching the render texture through Context3D::setRenderToTexture, you were required to clear it before drawing. In this release, we're removing this limitation and optimizing the use of render textures. This change will allow you to further optimize and reuse depth and stencil buffers between different render textures.
      For additional information, please see Relaxing Render Target Clear Operation in Stage 3D.
      • Improved support for browser zoom levels - Windows 8
      Flash Player now has improved support for browser zoom factors other than 100% on Internet Explorer on Windows 8.x.  Devices, like the Microsoft Surface tablets, default to a zoom level of 150%.  In the past, this could cause problems with Flash Player and some 3D content.  With our new implementation, we can now scale the content and 3D buffers to keep everything aligned.  In addition, Flash Player introduces an option to render to an increased Stage3D back buffer, rather than scaling, on browser zoom to keep the resolution of the rendered content high. This option allows to the stage3D buffer to change in size in synch with the change in the browser zoom factor.  Developers are notified of this change with a new ZOOM_FACTOR_CHANGE event.
      For additional detail, please see the article Improved Resolution of Stage3D Content on Browser Zoom
      • Flash Player Fullscreen Orientation Change - Windows
      Flash Player will now detect and appropriately scale your content to fit best in a fullscreen display when your device orientation is changed.  This change is specific to Windows and is implemented across all browsers.  We're focusing on providing the best tablet experience possible.  A resize event will fire when in fullscreen mode and the device orientation changes.  Developers, if your content does not resize, you will need to handle the resize event appropriately.  Additional details will be made available in a separate blog post.
      For additional details, please see the Guide for Supporting Screen Orientation with Full-Screen Flash Player Content.
      • Hardware video decoding on Chrome (PPAPI) for Windows
      We're pleased to announce that hardware video decoding is now enabled by default for Chrome users on Windows.  This feature will drastically reduce the CPU usage and improve performance on supported videos players.  We're working closely with Google to bring this feature to OS X and will provide additional details when available.
      • Automatic software fall back with StageVideo
      Flash Player 15 now supports a Software version of StageVideo that provides an automatic failover to the software version when hardware StageVideo is not available. To leverage this automatic failover, the swf apps need to be compiled for Flash Player 15 and above.
      When the swfs are compiled for Flash Player 15 and above, and when hardware StageVideo is unavailable, the app will get a StageVideoAvailability event as earlier, but instead of being "Unavailable" it will ALWAYS be "available", and the reason will always be "noError". The app will no longer need to implement a Video object failover as the failover is automatic inside flash player. The apps can still choose to use Video object instead of StageVIdeo if needed.
      Hardware StageVideo availability is dependent on a number of factors, including:
      Browser hardware rendering support: If available, all wMode based apps will support hardware StageVideo. If not available, wMode=direct based apps will be the only ones that will support hardware StageVideo, unless there are other exceptions, like the ones mentioned below.
      On Windows:
      IE11: IE has an accelerated pipeline and the FlashPlayer is HW accelerated in all wmode, so StageVideo should always be available. Note that the decision to use the HW accelerate rendering pipeline reside in IE.
      Firefox: There is currently no HW accelerated pipeline available in Firefox on windows and only wMode direct will have StageVideo available all other wMode should generate a unavailable event.
      Chrome: Pepper has HW acceleration in all wMode, but some restrictions apply. For example Chrome will refuse to use HW acceleration on Windows XP and it has its own driver blacklisting mechanism. It is also possible for the user to disable the HW acceleration in the settings panel. Chrome exposes a somewhat useful page to allow one to see the status of its gpu acceleration: chrome://gpu/
      On Mac:
      Safari: All wMode should expose StageVideo
      Firefox: All wModes should expose StageVideo
      Chrome: All wMode should expose StageVideo, with the same limitations as the windows version.
      Driver version: Certain older drivers may not support hardware StageVideo
      User settings: If a user turns off hardware acceleration, then hardware StageVideo will not be available
      Full Screen: Hardware StageVIdeo is always available in Full Screen mode.
      When the hardware StageVideo fails because of browser support, wMode, driver version or user settings, starting with Flash Player 15, SW StageVideo will be used automatically without needing any configuration or code in the app.
      For complete information please see our release notes.
      Fixed Issues
      • [Win8.1][IE11] Resolves an issue introduced with Flash Player 13.0.0.182 that affected Dragon Quest Monster Parade (3818827)
      • [Win8.x][IE10+] printJob.addPage() no longer throws an erroneous exception (3822297)
      • [Win8.x] Fixes an issue where Print To Printer only printed the first page (3825794)
      • [Win8.x][MSFT 654468] Full-Screen content is incorrectly scaled when the user requests Full-Screen Mode after zooming in or out with the browser zoom (3822208)
      • [Win][Firefox] Fixes an issue where FileReference.browse() file dialog was opening behind the browser window (3822025)
      • [Mac] Resolves an issue introduced with Flash Player 15.0.0.29.  Using the volume keys on the keyboard now works as expected in Adobe Connect (3827641)
      • [Mac] Resolves an infrequent issue where the Flash Player installer could not determine the correct OS version for users on MacOS 10.8+ (3814718)
      • [Mac 10.9+] Resolves an issue where Flash Player would use a large amount of CPU if the network was disconnected while a video using the Adobe Video Engine was playing (3811674)
      • Stage3D Content is now available on the Nvidia Tegra K1 (3809317)
      • WebVTT Captions are now correctly displayed after a mid-roll ad is inserted into a video stream (3809912)
      • [HTTP Live Streaming] The lowest possible bitrate i-frame stream was not being used if TrickPlay was enabled (3812854)
      Current Flash Player desktop users that have enrolled in the "Allow Adobe to install updates (recommended)" or the "Notify me to install updates" update options will receive an update notification dialog within 7 days from today (please note that Windows users will need to restart their system to receive the notification dialog.)
      Please note that both Flash Player for Google Chrome and Microsoft Internet Explorer for Windows 8.x are updated using different mechanisms.  Flash Player for Google Chrome updates will occur during regular Chrome updates.  Flash Player updates for Internet Explorer on Windows 8.x will be provided by Microsoft though the Windows automatic update feature.
      If you would like to install the update immediately, please use one of the links below:
      Flash Player 15 desktop for Windows XP, Vista and 7 and Internet Explorer (ActiveX): 15.0.0.189
      Flash Player 15 desktop for Windows XP, Vista and 7 and Other Browsers (NPAPI): 15.0.0.189
      Flash Player 15 for Internet Explorer on Windows 8.1 (64-bit machine): 15.0.0.189
      Flash Player 15 for Internet Explorer on Windows 8.1 (32-bit machine): 15.0.0.189
      Flash Player 15 for Internet Explorer on Windows 8 (64-bit machine): 15.0.0.189
      Flash Player 15 for Internet Explorer on Windows 8 (32-bit machine): 15.0.0.189
      Flash Player 15 desktop for Mac (NPAPI): 15.0.0.189
      Flash Player 11.2 desktop for Linux (NPAPI): 11.2.202.411
      Flash Player 13 Extended Support Release for Windows and Macintosh: 13.0.0.250
      Previous versions of Flash Player can be found on the Flash Player Archive page
      If you encounter a problems with broken or missing links, please clear your browser cache and try again.  If the problem persists, please create a new post in our forum or send email to ccampbel@adobe.com.
