5 Replies Latest reply on Oct 15, 2014 5:23 AM by try67
    Stamp with Check boxes and Text
    Scott44
      Im attempting to create a stamp with 6 check boxes and two text boxes. When placing the stamp I want the user prompted to check one and enter the date and their name. I pieced together most of this from different codes I found searching, and added some stuff along the way. I am able to get the prompt to come up, however I get the error: 'InvalidSetError: Set not possible, invalid or unknown. Event.value:156:Field Text7:Calculate' Anyone know how to fix this?
      Here is the code I am using:
         var DiaBox =
      result:"cancel",
      DoDialog: function(){return app.execDialog(this);},
      bChk1:false,
      bChk2:false,
      bChk3:false,
      bChk4:false,
      bChk5:false,
      stredt1:"",
      stredt2:"",
      initialize: function(dialog)
      var dlgInit =
      "Chk1": this.bChk1,
      "Chk2": this.bChk2,
      "Chk3": this.bChk3,
      "Chk4": this.bChk4,
      "Chk5": this.bChk5,
      "Chk6": this.bChk6,
      "edt7": this.stredt7,
      "edt8": this.stredt8,
      dialog.load(dlgInit);
      commit: function(dialog)
      var oRslt = dialog.store();
      this.bChk1 = oRslt["Chk1"];
      this.bChk2 = oRslt["Chk2"];
      this.bChk3 = oRslt["Chk3"];
      this.bChk4 = oRslt["Chk4"];
      this.bChk5 = oRslt["Chk5"];
      this.bChk6 = oRslt["Chk6"];
      this.edt7 = oRslt["edt7"];
      this.edt8 = oRslt["edt8"];
      description:
      elements:
      type: "view",
      elements:
      type: "view",
      char_height: 10,
      elements:
      type: "static_text",
      item_id: "stat",
      name: "Check only ONE box:",
      width: 152,
      height: 23,
      char_width: 15,
      alignment: "align_fill",
      font: "dialog",
      type: "check_box",
      item_id: "Chk1",
      name: "Approved as Submitted",
      type: "check_box",
      item_id: "Chk2",
      name: "Approved as Noted",
      type: "check_box",
      item_id: "Chk3",
      name: "Submit Specified Items",
      type: "check_box",
      item_id: "Chk4",
      name: "Revise and Resubmit",
      type: "check_box",
      item_id: "Chk5",
      type: "check_box",
      item_id: "Chk6",
      item_id: "sta1",
      alignment: "align_row",
      type: "edit_text",
      item_id: "edt1",
      char_width: 20,
      char_height: 6,
      alignment: "align_left",
      item_id: "sta2",
      type: "edit_text",
      item_id: "edt1",
      char_width: 20,
      char_height: 6,
      type: "ok_cancel",
      // Example Code
      //DiaBox.bChk1 = false;
      //DiaBox.bChk2 = false;
      //DiaBox.bChk3 = false;
      //DiaBox.bChk4 = false;
      //DiaBox.bChk5 = false;
      //DiaBox.bChk6 = false;
      //DiaBox.stredt7 = "";
      //DiaBox.stredt8 = "";
      if(event.source && event.source.forReal && (event.source.stampName == "#tKJfONHcAO3im7LqqlSJ3B"))
        if ("ok" == app.execDialog(DiaBox))
          this.getField("cbx1").checkThisBox(0, DiaBox.bChk1);
          this.getField("cbx2").checkThisBox(0, DiaBox.bChk2);
          this.getField("cbx3").checkThisBox(0, DiaBox.bChk3);
          this.getField("cbx4").checkThisBox(0, DiaBox.bChk4);
          this.getField("cbx5").checkThisBox(0, DiaBox.bChk5);
          var cMsg = DiaBox.byName;
          event.value = cMsg;
          event.source.source.info.exhibit = cMsg;
