1. Re: Is there a way to set up a Map ID on an image within a dropdown hotspot?
Captiv8r Oct 14, 2014 2:17 PM (in response to ktbFL)Hi there
I'm not sure you know what you really want. Or maybe you aren't understanding what Map IDs or for. Maybe both?
Typically a Map ID is used when you have help linked to an application. The Map ID is a unique identifier that is used to connect the call to the appropriate help topic.
What you are describing seems that you simply want a way to allow the user to return to the top of a topic. For that, the process is "fall off a log" stupid simple. Just select whatever you want the user to click. It may be text that reads "Back to top" or an image of some sort. Then click Insert > Hyperlink. And in the field where you would normally see the path and HTML topic file name, you just type a pound (or hash) symbol ( # ). Click OK on the dialog and you have an instant Back To Top link.
Cheers... Rick
2. Re: Is there a way to set up a Map ID on an image within a dropdown hotspot?
ktbFL Oct 14, 2014 3:40 PM (in response to Captiv8r)I think I misspoke... It was the end of a hectic day... Sorry... I meant an
image map... Not a map id... DOH... 2 different things... I know... I guess
I had MAP on the brain. It was stupid simple to do in Flare through the
design interface, but couldn't figure out any similar feature in RH....
However... I am going to try tweaking the html code as you suggest...
If i can't get it to work I will be back... Sorry!
But if I am successful, I shall return with kudos for you!
Thanks for your patience with such an airhead!
3. Re: Is there a way to set up a Map ID on an image within a dropdown hotspot?
ktbFL Oct 15, 2014 5:02 AM (in response to Captiv8r)you are BRIL! THANK YOU! IT WORKED!
