Receiving errors about Cold Fusion in the Event Log. CF10 is not able to run any scheduled tasks we have set up and so are troubleshooting. Keep getting the following two errors when I restart the service but am receiving no information from the error.
The description for Event ID 3 from source ColdFusion 10 Application Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
936
The description for Event ID 4 from source ColdFusion 10 Application Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
Moving this discussion to the ColdFusion forum.
