6 Replies Latest reply on Oct 19, 2014 8:39 PM by shuo_yang
    Update to Extension Manager in CC2014 to Version 7.3.2.39.
    MrMahootleCreative Level 1
      Updated Extension Manager in CC2014 to Version 7.3.2.39. No Products are showing only 'Others'. Can not see any installed extensions or any CC applications.
      iMac, CC2014, OS 10.9.5.
        • 1. Re: Update to Extension Manager in CC2014 to Version 7.3.2.39.
          Carl Sun Level 4
          EM-supported products will write their information into Product Configuration Database (PCD) during their installation, including name, version, locale, installation location, etc.. EM will get product information from PCD at launch. If EM can't find a product in recorded location, EM will not list it. So the most possible root cause is that wrong installation location was recorded in PCD.
          To confirm it, please install ExtendScript Toolkit CC from Creative Cloud application. Launch it, input "BridgeTalk.__diagnostics__;" (Exclude the double quotation marks) in the main window, then click "Debug"->"Run" menu item. The result will be output in the JavaScript Console window at the top right corner. Please check whether you can find  CC 2014 applications in the "Targets" section and whether their paths are correct.
          • 2. Re: Update to Extension Manager in CC2014 to Version 7.3.2.39.
            Carl Sun Level 4
            Could you see applications listed in EM before you update EM?
            • 3. Re: Update to Extension Manager in CC2014 to Version 7.3.2.39.
              Hi Carl,
              Yes, before the October updates everything was ok.
              Ta
              Drew
              Drew Buckmaster
              CMC Cross Media Communication
              801/6A Glen St  |  Milsons Point NSW 2061 | P: 02 9954 5488  |  www.c-media-c.com.au
              The information transmitted is intended only for the person(s)or entity to which it is addressed and may
              contain confidential and/or legally privileged material. Delivery of this message to any person other than
              the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review,
              retransmission, dissemination or other use of, or taking of any action in reliance upon, this information
              by entities other than the intended recipient is prohibited. If you receive this in error, please contact the
              sender and delete the material from any computer.
              • 4. Re: Update to Extension Manager in CC2014 to Version 7.3.2.39.
                Hi Carl,
                I have downloaded and run the ExtendScript Toolkit.
                The log that has the ‘targets’ does not include any CC2014 apps.
                I’ve copied the text and it is below.
                Ta
                Drew
                     Targets: 2
                          Connector = PCD
                          Installed: 0
                          Running: 0
                               estoolkit-4.0: PUMPING
                                    Group = cs
                                    Path = /Applications/Adobe ExtendScript Toolkit CC/ExtendScript Toolkit.app
                                    Display Name = ExtendScript Toolkit CC
                                    MsgAuthentication = ON
                                    MsgDigest = ON
                                    ESTK = ON
                                    Status = PUMPING
                                    Info:
                                         Group = cs
                                         Version = 2.0
                                         Build = ES 4.5.5
                                         Next serial number = 73
                                         Logging: = OFF
                                         Now = 13:28:01
                                              Message Version = 2.05
                                              Authentication = ON
                                              Digest = ON
                                    Thread: estoolkit-4.0#thread
                                         Avg. pump interval = 60ms
                                         Last pump = 239ms ago
                                         Ping: 7
                                              ECHO_REQUEST: ECHO_RESPONSE
                                                   Timeout = undefined
                                                   Handler = undefined
                                              STATUS: PUMPING
                                                   Timeout = undefined
                                                   Handler = undefined
                                              MAIN: MAIN
                                                   Timeout = undefined
                                                   Handler = installed
                                              LAUNCHED: LAUNCHED
                                                   Timeout = undefined
                                                   Handler = installed
                                              DIAGNOSTICS: DIAGNOSTICS
                                                   Timeout = undefined
                                                   Handler = installed
                                              INFO: INFO
                                                   Timeout = undefined
                                                   Handler = installed
                                              SETUPTIME: thread=0ms, left=15ms
                                                   Timeout = undefined
                                                   Handler = undefined
                                    ExeName = ExtendScript Toolkit.app
                               exman-7.0:
                                    Group = cs
                                    Path = /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app
                                    Display Name = Adobe Extension Manager CC
                                    MsgDigest = ON
                                    ESTK = OFF
                                    BundleID = com.adobe.exman
                                    Status = (not running)
                                    ExeName = Adobe Extension Manager CC.app
                          Installed: 1
                          Running: 1
                          Groups: 139
                               cs3:
                                    acrobat-8.0
                                    aftereffects-8.0
                                    soundbooth-1.0
                                    bridge-2.0
                                    contribute-4.5
                                    devicecentral-1.0
                                    dreamweaver-9.0
                                    encore-3.0
                                    estoolkit-2.0
                                    fireworks-9.0
                                    flash-9.0
                                    illustrator-13.0
                                    indesign-5.0
                                    indesignserver-5.0
                                    incopy-5.0
                                    photoshop-10.0
                                    premiere-3.0
                                    premierepro-3.0
                                    stockphotos-1.5
                                    audition-3.0
                               cs4:
                                    acrobat-9.0
                                    aftereffects-9.0
                                    soundbooth-2.0
                                    bridge-3.0
                                    contribute-5.0
                                    devicecentral-2.0
                                    dreamweaver-10.0
                                    encore-4.0
                                    estoolkit-3.0
                                    fireworks-10.0
                                    flash-10.0
                                    illustrator-14.0
                                    indesign-6.0
                                    indesignserver-6.0
                                    incopy-6.0
                                    photoshop-11.*
                                    premierepro-4.0
                                    audition-4.0
                                    ame-1.0
                                    exman-2.0
                               cs5:
                                    acrobat-9.0
                                    aftereffects-10.0
                                    soundbooth-3.0
                                    bridge-4.0
                                    contribute-6.0
                                    devicecentral-3.0
                                    dreamweaver-11.0
                                    encore-5.0
                                    estoolkit-3.5
                                    fireworks-11.0
                                    flash-11.0
                                    illustrator-15.0
                                    indesign-7.0
                                    indesignserver-7.0
                                    incopy-7.0
                                    photoshop-12.*
                                    premierepro-5.0
                                    audition-5.0
                                    ame-2.0
                                    exman-3.0
                                    flashbuilder-4.0
                                    flashcatalyst-1.0
                               ts1:
                                    captivate3-en_us
                                    captivate3-fr_fr
                                    captivate3-it_it
                                    captivate3-ja_jp
                                    captivate3-es_es
                                    captivate3-de_de
                               ts2:
                                    captivate-4.0
                               el2:
                                    captivate-5.0
                               as1:
                                    acrobat-10.0
                               ts3:
                                    robohelp-9.0
                                    framemaker-10.0
                               cs55:
                                    aftereffects-10.5
                                    audition-4.0
                                    bridge-4.1
                                    contribute-6.1
                                    devicecentral-3.5
                                    dreamweaver-11.5
                                    encore-5.1
                                    estoolkit-3.6
                                    fireworks-11.1
                                    flash-11.5
                                    illustrator-15.1
                                    indesign-7.5
                                    indesignserver-7.5
                                    incopy-7.5
                                    photoshop-55.*
                                    premierepro-5.5
                                    ame-2.5
                                    exman-5.5
                                    flashbuilder-4.5
                                    flashcatalyst-1.5
                                    switchboard-2.0
                               el25:
                                    captivate-5.5
                               cs60:
                                    aftereffects-11.0
                                    audition-5.0
                                    bridge-5.*
                                    contribute-6.88
                                    devicecentral-4.0
                                    dreamweaver-12.0
                                    encore-6.0
                                    estoolkit-3.8
                                    fireworks-12.0
                                    flash-12.0
                                    illustrator-16.*
                                    indesign-8.0
                                    indesignserver-8.0
                                    incopy-8.0
                                    photoshop-60.*
                                    premierepro-6.0
                                    ame-6.0
                                    exman-6.0
                                    flashbuilder-4.52
                                    switchboard-2.0
                                    prelude-1.0
                                    speedgrade-6.0
                               el60:
                                    captivate-60.*
                               ts4:
                                    robohelp-10.0
                                    framemaker-11.0
                               cs70:
                                    audition-6.0
                                    bridge-6.*
                                    dreamweaver-13.0
                                    encore-7.0
                                    fireworks-13.0
                                    flash-13.0
                                    illustrator-17.*
                                    indesign-9.*
                                    indesignserver-9.0
                                    incopy-9.*
                                    photoshop-70.*
                                    premierepro-7.0
                                    ame-7.0
                                    exman-7.0
                                    flashbuilder-5.0
                                    prelude-2.0
                                    estoolkit-4.0
                                    aftereffects-12.0
                               el70:
                                    captivate-70.*
                • 5. Re: Update to Extension Manager in CC2014 to Version 7.3.2.39.
                  Carl Sun Level 4
                  Then the PCD is incorrect. The normal output looks like the following. You have to follow Use the CC Cleaner Tool to solve installation problems | CC, CS3-CS6 to re-install all CC 2014 products.
                  Result: BridgeTalk Diagnostics
                      Info:
                          Name = estoolkit-4.0
                          Status = PUMPING
                          Group = cs
                          Version = 2.0
                          Build = ES 4.5.5
                          Next serial number = 41
                          Logging: = OFF
                          Now = 16:33:35
                              Authentication = ON
                              Digest = ON
                          Avg. pump interval = 62ms
                          Last pump = 87ms ago
                          Ping: 7
                                  Timeout = undefined
                                  Handler = undefined
                              STATUS: PUMPING
                                  Timeout = undefined
                                  Handler = undefined
                              MAIN: MAIN
                                  Timeout = undefined
                                  Handler = installed
                              LAUNCHED: LAUNCHED
                                  Timeout = undefined
                                  Handler = installed
                                  Timeout = undefined
                                  Handler = installed
                              INFO: INFO
                                  Timeout = undefined
                                  Handler = installed
                              SETUPTIME: thread=0ms, left=45ms
                                  Timeout = undefined
                                  Handler = undefined
                      Instances: 3
                          estoolkit-4.0#dbg:
                                  msg[16:33:35]: 00000036
                                      @BT>Version = 2.05
                                      Target = estoolkit-4.0#dbg
                                      Sender = estoolkit-4.0#dbg
                                      Sender-ID = localhost:mac1069
                                      Timeout = 16:33:36
                                      Type = Ignore
                                      Response-Request = Timeout
                                      Headers = (no headers)
                                      Timestamp = 16:33:35
                                      Serial-Number = 36
                                      Received = undefined
                                      Result = undefined
                                      Error = undefined
                                      Body = (empty)
                              Incoming: 1
                              Outgoing: 0
                              Handler: 9
                                  ExtendScript = for all messages
                                  Error = for only msg #25
                                  Error = for only msg #27
                                  Error = for only msg #32
                                  Result = for only msg #36
                                  Error = for only msg #36
                                  Timeout = for only msg #36
                                  Result = for only msg #38
                                  Error = for only msg #38
                          estoolkit-4.0#estk:
                                  msg[16:33:35]: 00000038
                                      @BT>Version = 2.05
                                      Target = estoolkit-4.0#estk
                                      Timeout = 16:43:35
                                      Type = Debug
                                      Response-Request = Result Error
                                      Serial-Number = 38
                                      Result = undefined
                                      Error = undefined
                                      Body: 107 bytes
                                          Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                              Incoming: 1
                              Outgoing: 0
                              Handler: 1
                          estoolkit-4.0: (main)
                              Incoming: 0
                              Outgoing: 0
                              Handler: 1
                      Targets: 11
                          Connector = PCD
                          Installed: 0
                          Running: 0
                              ame-7.0:
                                  Group = cs
                                  Path = /Applications/Adobe Media Encoder CC/Adobe Media Encoder CC.app
                                  Display Name = Adobe Media Encoder
                                  MsgDigest = ON
                                  ESTK = ON
                                  BundleID = com.adobe.ame.application
                                  ExeName = Adobe Media Encoder CC.app
                              dreamweaver-12.0:
                                  Group = cs
                                  Path = /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app
                                  Display Name = Adobe Dreamweaver CS6
                                  MsgDigest = ON
                                  ESTK = OFF
                                  BundleID = com.adobe.dreamweaver-12.0
                                  ExeName = Adobe Dreamweaver CS6.app
                              dreamweaver-13.0:
                                  Group = cs
                                  Path = /Applications/Adobe Dreamweaver CC/Adobe Dreamweaver CC.app
                                  Display Name = Adobe Dreamweaver CC
                                  MsgDigest = ON
                                  ESTK = OFF
                                  BundleID = com.adobe.dreamweaver-13.0
                                  ExeName = Adobe Dreamweaver CC.app
                                  Group = cs
                                  MsgDigest = ON
                                  ESTK = ON
                                  Status = PUMPING
                                  Info:
                                      Group = cs
                                      Version = 2.0
                                      Build = ES 4.5.5
                                      Next serial number = 47
                                      Logging: = OFF
                                      Now = 16:33:36
                                          Authentication = ON
                                          Digest = ON
                                      Last pump = 290ms ago
                                      Ping: 7
                                              Timeout = undefined
                                              Handler = undefined
                                          STATUS: PUMPING
                                              Timeout = undefined
                                              Handler = undefined
                                          MAIN: MAIN
                                              Timeout = undefined
                                              Handler = installed
                                          LAUNCHED: LAUNCHED
                                              Timeout = undefined
                                              Handler = installed
                                              Timeout = undefined
                                              Handler = installed
                                          INFO: INFO
                                              Timeout = undefined
                                              Handler = installed
                                              Timeout = undefined
                                              Handler = undefined
                              exman-6.0:
                                  Group = cs
                                  Path = /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app
                                  Display Name = Adobe Extension Manager CS6
                                  MsgDigest = ON
                                  ESTK = OFF
                                  ExeName = Adobe Extension Manager CS6.app
                              exman-7.0:
                                  Group = cs
                                  MsgDigest = ON
                                  ESTK = OFF
                              illustrator-18.064:
                                  Path = /Applications/Adobe Illustrator CC 2014/Adobe Illustrator.app
                                  Display Name = Adobe Illustrator CC 2014
                                  MsgDigest = ON
                                  ESTK = ON
                                  BundleID = com.adobe.illustrator
                                  ExeName = Adobe Illustrator.app
                              indesign-10.064:
                                  Path = /Applications/Adobe InDesign CC 2014/Adobe InDesign CC 2014.app
                                  Display Name = Adobe InDesign CC 2014
                                  MsgDigest = ON
                                  ESTK = ON
                                  BundleID = com.adobe.InDesign
                                  ExeName = Adobe InDesign CC 2014.app
                              indesign-9.064:
                                  Group = cs
                                  Path = /Applications/Adobe InDesign CC/Adobe InDesign CC.app
                                  MsgDigest = ON
                                  ESTK = ON
                                  ExeName = Adobe InDesign CC.app
                              photoshop-70.032:
                                  Group = cs
                                  Path = /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app
                                  Display Name = Adobe Photoshop CC
                                  MsgDigest = ON
                                  ESTK = ON
                                  BundleID = com.adobe.Photoshop
                                  ExeName = Adobe Photoshop CC.app
                              photoshop-80.032:
                                  Group = cs
                                  Path = /Applications/Adobe Photoshop CC 2014/Adobe Photoshop CC 2014.app
                                  Display Name = Adobe Photoshop CC 2014
                                  MsgDigest = ON
                                  ESTK = ON
                                  ExeName = Adobe Photoshop CC 2014.app
                          Installed: 10
                          Running: 1
                          Groups: 143
                              cs3:
                                  acrobat-8.0
                                  aftereffects-8.0
                                  soundbooth-1.0
                                  bridge-2.0
                                  contribute-4.5
                                  devicecentral-1.0
                                  dreamweaver-9.0
                                  encore-3.0
                                  estoolkit-2.0
                                  fireworks-9.0
                                  flash-9.0
                                  illustrator-13.0
                                  indesign-5.0
                                  indesignserver-5.0
                                  incopy-5.0
                                  photoshop-10.0
                                  premiere-3.0
                                  premierepro-3.0
                                  stockphotos-1.5
                                  audition-3.0
                              cs4:
                                  acrobat-9.0
                                  aftereffects-9.0
                                  soundbooth-2.0
                                  bridge-3.0
                                  contribute-5.0
                                  devicecentral-2.0
                                  dreamweaver-10.0
                                  encore-4.0
                                  estoolkit-3.0
                                  fireworks-10.0
                                  flash-10.0
                                  illustrator-14.0
                                  indesign-6.0
                                  indesignserver-6.0
                                  incopy-6.0
                                  photoshop-11.*
                                  premierepro-4.0
                                  audition-4.0
                                  ame-1.0
                                  exman-2.0
                              cs5:
                                  acrobat-9.0
                                  aftereffects-10.0
                                  soundbooth-3.0
                                  bridge-4.0
                                  contribute-6.0
                                  devicecentral-3.0
                                  dreamweaver-11.0
                                  encore-5.0
                                  estoolkit-3.5
                                  fireworks-11.0
                                  flash-11.0
                                  illustrator-15.0
                                  indesign-7.0
                                  indesignserver-7.0
                                  incopy-7.0
                                  photoshop-12.*
                                  premierepro-5.0
                                  audition-5.0
                                  ame-2.0
                                  exman-3.0
                                  flashbuilder-4.0
                                  flashcatalyst-1.0
                              ts1:
                                  captivate3-en_us
                                  captivate3-fr_fr
                                  captivate3-it_it
                                  captivate3-ja_jp
                                  captivate3-es_es
                                  captivate3-de_de
                              ts2:
                                  captivate-4.0
                              el2:
                                  captivate-5.0
                              as1:
                                  acrobat-10.0
                              ts3:
                                  robohelp-9.0
                                  framemaker-10.0
                              cs55:
                                  aftereffects-10.5
                                  audition-4.0
                                  bridge-4.1
                                  contribute-6.1
                                  devicecentral-3.5
                                  dreamweaver-11.5
                                  encore-5.1
                                  estoolkit-3.6
                                  fireworks-11.1
                                  flash-11.5
                                  illustrator-15.1
                                  indesign-7.5
                                  indesignserver-7.5
                                  incopy-7.5
                                  photoshop-55.*
                                  premierepro-5.5
                                  ame-2.5
                                  exman-5.5
                                  flashbuilder-4.5
                                  flashcatalyst-1.5
                                  switchboard-2.0
                              el25:
                                  captivate-5.5
                              cs60:
                                  aftereffects-11.0
                                  audition-5.0
                                  bridge-5.*
                                  contribute-6.88
                                  devicecentral-4.0
                                  dreamweaver-12.0
                                  encore-6.0
                                  estoolkit-3.8
                                  fireworks-12.0
                                  flash-12.0
                                  illustrator-16.*
                                  indesign-8.0
                                  indesignserver-8.0
                                  incopy-8.0
                                  photoshop-60.*
                                  premierepro-6.0
                                  ame-6.0
                                  exman-6.0
                                  flashbuilder-4.52
                                  switchboard-2.0
                                  prelude-1.0
                                  speedgrade-6.0
                              el60:
                                  captivate-60.*
                              ts4:
                                  robohelp-10.0
                                  framemaker-11.0
                              cs70:
                                  audition-6.0
                                  bridge-6.*
                                  dreamweaver-13.0
                                  encore-7.0
                                  fireworks-13.0
                                  flash-13.0
                                  illustrator-17.*
                                  indesign-9.*
                                  indesignserver-9.0
                                  incopy-9.*
                                  photoshop-70.*
                                  premierepro-7.0
                                  ame-7.0
                                  exman-7.0
                                  flashbuilder-5.0
                                  prelude-2.0
                                  estoolkit-4.0
                                  aftereffects-12.0
                              el70:
                                  captivate-70.*
                              cs70:
                                  switchboard-3.*
                              cs80:
                                  bridge-6.*
                                  photoshop-80.*
                                  estoolkit-4.0
                  • 6. Re: Update to Extension Manager in CC2014 to Version 7.3.2.39.
                    shuo_yang Level 2
                    Can you try follow steps?
                    1.  Create a file called exmancoreliblog.yes and copy it to
                    Mac: /Users/<name>/Library/Application Support/Adobe/Extension Manager CC/Log/
                    Windows: C:\Users\<name>\AppData\Roaming\Adobe\Extension Manager CC\Log
                    2. Delete Extension Manager database file  then restart Extension Manager and reproduce your issue
                    Mac: "Macintosh HD/Library/Application Support/Adobe/Extension Manager CC/Configuration/DB/ExMan.db"
                    Windows: C:\ProgramData\Adobe\Extension Manager CC\Configuration\DB\ExMan.db
                    3. Send us ExManCoreLibrary.log file in that log folder to exman.beijing@gmail.com
