0 Replies Latest reply on Oct 14, 2014 5:51 PM by liquid One
    Mobile form not calculating on Android Tablet
    liquid One
      I have a Time Sheet with Javascript that adds the times up, and it works perfect with the PC version of Adobe Reader, but when I try to use it on a nexus 7 tablet the calculations don't work.
      I have tried the official Adobe Reader for Android as well as about a dozen other readers.  If there is a reader that will work with this sheet as is, I don't mind paying for it, or perhaps part of my JavaScript is not supported on mobile, and I can change it with a workaround.
      Please Take a look and see what you can see:
      PR_Form_Tablet6.pdf - Google Drive
      I have 2 Functions in here:
      TimeDiff Function:
      function TimeDiff(cStartField, cEndField) {
      var sTimeFormat = 'hh:mm';
      var fDiff = 0;
      // get the start time
      var sStart = this.getField(cStartField).value;
      // get the end time
      var sEnd = this.getField(cEndField).value;
      // complete script only if we have data
      if(sStart != '' & sEnd != '') {
      // convert sStart string to seconds
      var fStart = Time2Num(sTimeFormat, sStart);
      // convert sEnd string to seconds
      var fEnd = Time2Num(sTimeFormat, sEnd);
      // compute difference in seconds
      fDiff += fEnd - fStart;
      return fDiff;
      Time2Num Function:
      function Time2Num(sFormat, sTime) {
      convert time string (sTime) with format of sFormat
      to the seconds since the start of the day
      if(sTime == '') return ''; // exit
      // get date time for Epoch date and sTime
      var oTime = util.scand('mm/dd/yyyy ' + sFormat, '01/01/1970 ' + sTime);
      // convert UTC Offset to milliseonds for adjustment
      var fTZOffset = oTime.getTimezoneOffset() * 1000 * 60
      // time since the start of the day in millseconds
      var fTime = oTime.valueOf() - fTZOffset;
      // convert to seconds and return value
      return Math.round(fTime / 1000);
      And here is a sample field with JavaScript in it:
      event.value = '';
      var fDiff = 0;
      // compute the difference for first pair of fields
      var sStart = this.getField('Tech_2_Start').value;
      // get the end time
      var sEnd = this.getField('Tech_2_End').value;
      var fStart = Time2Num('hh:mm', sStart);
      var fEnd = Time2Num('hh:mm', sEnd);
      fDiff = TimeDiff('Tech_2_Start', 'Tech_2_End');
      // compute and add the difference for the second pair of fields
      var sStart = this.getField('Tech_2_Start_2').value;
      // get the end time
      var sEnd = this.getField('Tech_2_End_2').value;
      fDiff += TimeDiff('Tech_2_Start_2', 'Tech_2_End_2');
      // convert to rounded minutes if not zero
      if (fDiff != 0) {
      fDiff = Math.round(fDiff / 60);
      // report decimal hours
      event.value = fDiff / 60;
      Mike
