2 Replies Latest reply on Oct 15, 2014 9:38 AM by Amy Blankenship
    Flash using arrow keys to move between frames in an animation
    Dr Technology
      Im currently creating a calculator on flash and I would like to be able to move to the next part of the calculator (the next frame) by using the arrow keys on my keyboard
      This is my current code to move between the frames using a buttons.
      stop();
      var input1:String;
      var input2:String;
      var Res:Number;
      var Quote:Number;
      txtLen.restrict = "0-9"
      txtWid.restrict = "0-9"
      BtnCon2.addEventListener(MouseEvent.CLICK,fnCall)
      function fnCall(Event:MouseEvent):void{
        input1 = txtLen.text;
        input2 = txtWid.text;
        Res = parseInt(input1) * parseInt(input2);
        Res.toString();
        gotoAndPlay(21)
        txtArea.text = String(Res);
      BtnRes1.addEventListener(MouseEvent.CLICK,fnRes1)
      function fnRes1(Event:MouseEvent):void{
        gotoAndPlay(1);
      Im trying to do the same thing that im doing with my buttons but with my arrow keys
        • 1. Re: Flash using arrow keys to move between frames in an animation
          Here is a somewhat generic bit of code involving the arrows keys....
          function hearKeyUp(yourEvent:KeyboardEvent):void{
               if (yourEvent.keyCode==Keyboard.RIGHT){  processing code goes here }
               if (yourEvent.keyCode==Keyboard.LEFT){  processing code goes here }
               if (yourEvent.keyCode==Keyboard.UP){  processing code goes here }
               if (yourEvent.keyCode==Keyboard.DOWN){  processing code goes here }
          stage.addEventListener(KeyboardEvent.KEY_UP, hearKeyUp);
          • 2. Re: Flash using arrow keys to move between frames in an animation
            Amy Blankenship Level 4
            Another way to write what Ned said is instead of multiple if's, you could do something like:
            switch(yourEvent.keyCode) {
                 case Keyboard.RIGHT:
                      fnCall(null);
                      break;
                 case Keyboard.LEFT:
                      fnRes1(null);
                      break;
                 case Keyboard.UP:
                      //do up stuff
                      break;
                 case Keyboard.DOWN:
                      //do down stuff
                      break;
                 default:
                      trace('I\'m confused by this key.');
                      break;
            Some people find this syntax more legible.
