2 Replies Latest reply on Oct 15, 2014 2:51 AM by xpozd
    . - error occurred
      using dreamweaver cs5 i receive this ftp error when trying to upload certain files to my server.
      index.php - Put operation successful
      . - error occurred - Access denied.  The file may not exist locally,  may be open in another program, or there could be a local permission problem.
      File activity incomplete. 1 file(s) or folder(s) were not completed.
      Files updated: 1
      Files with errors: 1
      this error does NOT happen for all files just a few.
      it does upload/download the files but on uploading it displays the error in ftp log.
      my host says website/ftp is fine and that this would be a local issue.
      they suggest i use filezilla instead but id prefer dreamweaver.
        • 1. Re: . - error occurred
          BenPleysier Adobe Community Professional & MVP
          Personally I would first try with FileZilla. If that works, then try using one of the options for the Dreamweaver FTP-setup.
          • 2. Re: . - error occurred
            xpozd Level 1
            thanks for the suggestion Ben,
            I use both settings as well, I believe this may be a deeper issue than just an ftp connection.
            I have just discovered i am using security software on my website that has been known not
            to play very well with dreamweaver in the past, so this is possibly caused by a broken script.
            and not dreamweaver as 1st thought. i will need to remove the script and set-up dreamweaver,
            and see how things work then. if i am still unsuccessful i will be sure to post back.
            thank you for your reply and suggestion though,
