2 Replies Latest reply on Oct 16, 2014 6:37 AM by NellievD
    How can I limit the entry options to specific alphabet characters or the numbers 1 to 100 in a text field?
    NellievD Level 1
      I've written a script on the change event in Adobe Livecycle Designer ES4 on the change* event which is supposed to do the following:
      Allow the user to enter any of the following values, but only ONE option is to be entered:
      Any numeric value from 1 to 100 (the field is limited to 3 characters)
      OR
      the entry of the value "na"
      OR
      the entry of the value "r"
      OR
      the entry of the value "i"
      Here is the script:
      // Test input in real time. Only allow approved grades, i, i, na
      if (xfa.event.change!="" && !xfa.event.newText.match(/^[0-9]+?$|^(na?)?$|^(r)?$|^(i)?$/))  {
           xfa.event.change ="";
           xfa.host.messageBox("Oops, incorrect entry, Please correct your input. Thank you.");
      On the exit event I've set the script to automatically uppercase the characters. This works
      Two problems:
      1. I can't restrict the numbers to be between 1 and 100.
      2. I can't restrict the entry of "na". The field still accepts "n" which I don't want.
      Is there a way to correct these two issues?  Thanks!
