So, I used the updater in CF Admin to apply the latest patch (14) to CF10. Afterwards, I rebuilt my web server connections. This is a process I've done dozens of times. However, this time around I've lost the ability to get to my CF Administrator....but all my sites are running just fine! I just can't access the Administrator! I've removed/recreated the connectors and restarted IIS/CF 3 times. Same thing.
Everything about this server was running fine up to now. It is Win 2008/IIS7
I'm getting the dreaded IIS HTTP Error 500.0 - Internal Server Error:
Module | IsapiModule |
Notification | ExecuteRequestHandler |
Handler | ISAPI-dll |
Error Code | 0x00000000 |
Requested URL | http://mywebsite:80/jakarta/isapi_redirect.dll |
Physical Path | D:\My_Web_Sites\config\wsconfig\2\isapi_redirect.dll |
Logon Method | Anonymous |
Logon User | Anonymous |
I have 2 other identical servers that I have yet to update so they continue to run fine. I've been referencing each of them to see if there were some permissions or other oddball changes. Can't find anything.
Any ideas?
Paul,
Can you reach out to cfinstal<AT>adobe<DOT>com with your server info.
Regards,
Anit Kumar
Anit,
Last time I did that Adobe asked for my Extended Support ID which I don't have. I told them I didn't have one but offered to purchase one. No one ever responded so I was left on my own.
Hi Paul,
Please send an email to cf.install@adobe.com or cfinstal@adobe.com. Install and Connector configuration are free, there is no charge for it.
Priyank
I have emailed them. Waiting for response.
Hi Paul,
I havn't received your email so far, I have sent you a private msg with my contact details. I have just worked with another user and fixed their problem.
Can you please uninstall the Update 14 and reinstall it manually. Recreate the connector and try again.
Priyank
sdsinc_pmascari,
In all likelihood, the following blog post should explain the cause and provide the solution to the issue you are facing:
The problem ended up being some 3rd party JAR files that had been installed in our cfusion/lib/ folder long ago. After moving these files to their proper location (cfusion/wwwroot/web-inf/lib/) update 14 installed and CF Admin access was restored.
