2 Replies Latest reply on Feb 3, 2007 11:36 AM by MRC06460CT
    createTextField() will not work with UI Component
    MRC06460CT
      I use ActionScript to create a TextField & it works fine.
      If I then add a UI component (say button or checkbox) to the stage the TextField stops displaying.
      If I remove the just the button on the stage the TextField still does not display. If I then remove the button component symbol from my library, the TextField displays again!!!
      Here is the script. It works as long as there is no UI component in the library.
      See Attached Code. It displays text, but will stop displaying if you put a button on the stage.
      Thanks for any help
      MRC06460CT
