2 Replies Latest reply on Jul 3, 2007 1:48 PM by kandy51
    Axis Label Issue
    kandy51
      My application creats custom graphs using AS3 and a mySQL database. Almost all of the graphs render just fine, except I have one that is supposed to set its vertical axis min to 0% and its max at 75% with intervals every 25%, and yet its labels render as 0%, 30%, 50%, and 80% instead of 0%, 25%, 50%, and 75%. The data and gridlines are correct, just the axis labels are wrong. If I set the min to anything other than 0, the labels are fine. This seems be a problem if the interval is set to anything other than 5 or 10 (like 15 or 25). Can anyone tell me if this is a Flex bug or if this issue might be caused by something else? This occurs on a development server and the live server and there are a couple of other graphs that have this same issue.
      The graph in question can be seen at http://www.communityindicators.ewu.edu/graph.cfm?id=106.
      Thank you in advance for your help.
