6 Replies Latest reply on Oct 18, 2014 6:58 AM by Obi-wan Kenobi
    Spilt a name which has more than one space
    LearnIndesignScripting
      I have a name as :  ashish Kumar Panday
      I just want first name into one sring and rest into other as :  F Name=ashish
      lName = Kumar Panday
      I am trying with this code but it not working
      var name="Alexandra De Poorter";
      var splitName=name.toString().indexOf (' ');
      var aspiltName=name.split (9);
      var fname=aspiltName[0];
      var LName=aspiltName[1];+ ",";
      //~ var LName=name.toString().split (splitName,name.length) + ",";
      var finalname=LName + fname;
        • 1. Re: Spilt a name which has more than one space
          cchimi Level 2
          One relatively simple way is to split the string on the space, creating an array of each element. Take the first element for the first name, and join the rest of the array back together to form the last name.
          var splitName = name.split(" ");
          var firstName = splitName.shift();
          var lastName = splitName.join(" ");
          var finalname = lastName + ", " + firstName;
          $.writeln(finalname);
          Note that shift() actually removes the first item from the array so you can simply join the rest together without worrying about the first name.
          • 2. Re: Spilt a name which has more than one space
            Kai Rübsamen Level 4
            Try this one:
            var name = "Alexandra De Poorter";
            var fName = name.slice( 0 , name.indexOf(" ") );
            var lName = name.slice( name.indexOf(" ") + 1 );
            alert ( fName + "\r" + lName + "\r" + fName + " "+ lName );
            • 3. Re: Spilt a name which has more than one space
              Peter Kahrel Adobe Community Professional & MVP
              Or this:
              var parts = name.match(/(.+?) (.+)/);
              var finalname = parts[2] + ', ' + parts[1];
              Peter
              • 4. Re: Spilt a name which has more than one space
                Obi-wan Kenobi Level 5
                Hi all,
                A little question, by curiosity:
                How manage these cases:
                John F. Kennedy
                John Fitzgerald Kennedy
                Eddy van Halen
                Louis Antoine de Saint-Just
                Charles de Gaulle
                … to obtain:
                Kennedy, John F.
                Kennedy, John Fitzgerald
                van Halen, Eddy
                Saint-Just (Louis Antoine de)
                de Gaulle (Charles)
                Thanks in advance!
                • 5. Re: Re: Spilt a name which has more than one space
                  Matching names is not so easy, especially because you won't be able to tell the difference between Portuguese and Spanish names such as my niece's name, Lara David Kahrel (who lives in Portugal), whose last name is 'David Kahrel', and John Fitzgerald Kennedy, whose last name is 'Kennedy'. That aside, your examples (and more) can be captured as follows:
                  var parts = name.match(/^(.+?) ((?:v[ao]n )?(?:d[eu]r? ?)?(?:la ?)?)?([^ ]+)$/i);
                  var finalname = "";
                  if (parts[2] != "") finalname = parts[2]; // if there are no prefixes, as in 'John Black', then parts[2] == ""
                  finalname += parts[3] + ', ' + parts[1];
                  The expression chops strings up in two or three parts: last name (everything from the last space to the end of the string), prefixes (any combination of 'van', 'von', 'van de', etc.), and first name (everything up to the first prefix or up to the last name. In this form it captures these (Dutch, Flemish, German, French) prefixes case-insensitively:
                  van/von
                  de
                  van/von der
                  van de
                  de
                  de la
                  le
                  la
                  You could add others, such as 't, op, della, etc. etc.
                  Peter
                  • 6. Re: Re: Spilt a name which has more than one space
                    Thanks Peter! And my greetings to your niece!
