1. Re: Why won't the PDF open from Webhelp
Captiv8r Oct 17, 2014 6:42 AM (in response to ktbFL)Hi there
First off...
Are you testing this locally? If so, are you using Microsoft Internet Explorer as your browser? Assuming that's the case, the browser is likely prohibiting links like that from working. One way around this is to simply upload the WebHelp to a web server. If you cannot do that, you need to relax IE's nervous nellie security. So look at your Options for IE and head to the Advanced tab. In the Security section, enable the option to allow active content.
Let us know how you get on... Rick
2. Re: Why won't the PDF open from Webhelp
ktbFL Oct 17, 2014 7:12 AM (in response to Captiv8r)Thanks Rick for your response... but boy... are you gonna be sorry! [?]
Unfortunately, things have gone from bad to worse... so here's what's
happening (or rather not happening).. even after making the security
setting as you state... and it's happening with chrome as well.. and yes..
I'm running it locally... we have to be able to run it locally for folks
that will be trying to access it without internet access... so here's the
full situation as it stands now:
IN WEBHELP:
1) PDF still isn't opening (it is set to open in New Window)
2) the video link i have to a quick vid on youtube IS working
3) the TOC, Index, and Search options aren't working - the nav pane is
showing up on the left, but it's empty.. and the search field is there, but
not working.
4) Image maps aren't working if set to go to a bookmark on the same page.
If the map is set to link to a different page it works fine... Just not if
the flag is on the same page (in dropdown text).
IN A CHM:
I tried generating a chm to see if the same issues occurred... here's what
happens:
3) the TOC, and Search options DO work, but Instead of an Index tab,
there's a Favorites tab and I can't see where I've missed setting the Index
up.
4) Image maps work to go to a bookmark on the same page (altho they don't
work to actually open the dropdown text where the bookmark resides - but
I'll take what I can get.
I'm having a hard time breaking habits set from working in Flare for over 5
years.... but I'm trying to remember and cover all bases, but I am
obviously missing SOMETHING!
Am I being too blonde or what?
THANKS!
3. Re: Why won't the PDF open from Webhelp
ktbFL Oct 17, 2014 7:18 AM (in response to Captiv8r)Also, I've applied a skin, but it's not working either...
4. Re: Why won't the PDF open from Webhelp
Peter Grainge Oct 17, 2014 9:26 AM (in response to ktbFL)There was a spate of browser issues some months back and Adobe issued a number of patches including one for Rh10.
Take a look at RoboHelp Patches and Updates | WvanWeelden.eu
5. Re: Why won't the PDF open from Webhelp
ktbFL Oct 20, 2014 12:21 PM (in response to Peter Grainge)OK... FINALLY GOT ALL THE PATCHES downloaded... and lo and behold... THERE
IS MY TOC AND INDEX! WOOOOHOOO... THANK YOU PETER GRAINGE! I you for
sure!
On Fri, Oct 17, 2014 at 12:27 PM, Peter Grainge <forums_noreply@adobe.com>
