CS3 compatible with Mac OS Yosemite?
it wasn't designed to be compatible (obviously) and apple generally does not design its os'es to be compatible with older software, but you can check other users experience - http://roaringapps.com/apps:table
Photoshop and Indesign worked directly after the upgrade. I had some trouble getting Illustrator to work:
I had problems with Adobe Illustrator CS3 and Yosemite. After the upgrade I installed Java for OS X 2014-001, as suggested by others. This seemed to work (sometimes) but when I opened Illustrator for the 2nd time it failed to open. Illustrator opened without crashing, but it did not show any menus, if I opened an .ai file the file did load and show on the screen, but I could not click on the window (unresponsive). Essentially this made Illustrator useless. I tried the following:
Nothing seemed to help. Until finally 15 minutes ago I found the solution by accident:
Hope this will also help others!
