1 Reply Latest reply on Apr 3, 2007 7:58 AM by AndyWW
    Flex Data Services JOTM, JTA and JMX downloads
    castlemac Level 1
      I am not a Java developer. I am an Information Architect/UI Designer and up until a few months ago, I designed GUIs using MS Studio.Net -- Tomcat is a little different IIS, to say the least. =)
      I have downloaded the trial software of Flex Builder 2 and Flex Data Services to test it with intent to purchase.
      I was getting real happy with Flex Builder 2. Breezing through the "Getting Started" and all the tutorials. Absolutely Love it.
      Then along comes Flex Data Services. This application has bought me to a screeching halt.
      I've downloaded the files according to the instructions at: http://www.adobe.com/support/documentation/en/flex/2/install.html#flexj2ee.
      I placed the files in my webapps directory running on tomcat. However, according to the instructions at:
      http://www.adobe.com/support/documentation/en/flex/2/install.html#tomcat,
      I need to download additional applications in order to correctly use FDS. I have tried to download the JOTM 2.0.10.tgz from
      http://forge.objectweb.org/project/download.php?group_id=19&file_id=3926
      without success. When I try to unzip the file (I am running Windows XP Professional), I get the following error:
      "Error reading header after processing 0 entries."
      I've tried to download three different versions of JOTM, no luck. Our Java developer suggested that I save the "tar" file as a "zip" file and try to open it after download. However, when I try to open the archive in WinZip it returns this error:
      "Cannot open file: it does not appear to be a valid archive. If you downloaded this file, try downloading the file again."
      Both of these errors occur when trying to open the downloaded JOTM 2.0.10.tgz and JOTM 2.0.8.tgz files.
      How can I get these applications? Has anyone had any success in downloading these files from: http://forge.objectweb.org/project/showfiles.php?group_id=19&release_id=1024
      The downloaded archive files are empty. I can not run any of the Data Service samples.
      When I tried at:
      http://localhost:8080/samples/dataservice/flexcab/flexcabDispatcher.mxml
      A service error prompt returns: "Unable to access UserTransaction in Dataservice".
      I'm assuming this is because the JOTM (et. al) is not on my box, because the archive is empty when I try to open it in WinZip.
      Also, while I was reading the installation instructions for Tomcat at:
      it seems pretty complicated for a non-Java programmer to understand. I asked one of our 6-year veteran Java developers here to help me with this and he said it was a pretty a complicated process for someone w/o Java programming experience. I thought it was geared towards front-end developers. But he did say that if I can't download the JOTM, I won't be able to do whatever it is that Flex Data Services is supposed to do. I say the latter because I am still in the "Getting Started" manual going through the last of the tutorials (which is the Flex Data Services distributed application tutorial) before I start reading "Using Flex", so I'm not really sure what lessons I will be doing that require FDS to work correctly on my box.
      Do I really need the FDS to build interactive applications in Flex Builder?
      I appreciate your answers. Thanks in advance.
        • 1. Re: Flex Data Services JOTM, JTA and JMX downloads
          AndyWW Level 1
          I agree with you about the process of getting FDS installed and working. I recommend that you try Christophe Coenraets FDMS tutorial. The JOTM files are in "tar" format, and so I think you'll have to extract them using a "tar" utility. This is included with any Unix variant, and so I asked someone at work to extract the files; on Windows I think you'll have to find a free "tar" program. I downloaded jotm-2.0.10.tar from the JOTM Sourceforge. Use parameters "-xf" if the tar file is not compressed, or "-zxf" if it is compressed. Good luck!
