1 Reply Latest reply on Oct 18, 2014 1:51 AM by Jump_Over
    My first script needs help
    My first script need help
      text<tab>{findWhat:”<U+0394>”}<tab>{appliedCharacterStyle:”Symbol”}<tab>{includeFootnotes: true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}
      In this case, I want to swap the Greek letter Delta, which is its codepoint U + 0394, for a specific character style (the style is called Symbol).
      The question is: is written right?
      Where should I put it? Because I'm just adding this line in an existing code ...
      Thanks anyway to everyone! ^^
        • 1. Re: My first script needs help
          Jump_Over Level 5
          You could  use "grep" mode instead of "text". I mean:
          grep<tab>{findWhat:"\x{394}"}<tab>{appliedCharacterStyle:"Symbol"}<tab>{includeFootnotes:t rue, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}
          findWhat:"\x{394}" means to find a unicode with specified number (the number you can see in InDesign Info Panel).
          This should be placed as a one of lines inside "FindChangeList.txt" file before "FindChangeByList.jsx" run.
          Jarek
