1. Re: diffrent look graficstyle
Monika Gause Oct 17, 2014 12:28 PM (in response to Sentruper)Please tell step by step what you're doing and what you are trying to achieve and what exactly does not work.
2. Re: diffrent look graficstyle
Sentruper Oct 19, 2014 9:25 AM (in response to Monika Gause)thanks for your answer. I deleted some virus, deinstalled and installed adobe CS6, because I thought the reason, that I can not
find/see the scribble-effect was a virus. Today I have a new installation
I open a new project, made a rectangel. In the menu colorfield, other library - I tried to give the rectangel a pattern (scribble-effect).
the scribble effect is no longer under the graficstyle. Some Days ago, the scribble effect was there, so i could diffrent
pattern with the scribble effect into the rectangel. Now the scribble effect shows only a color gradient.
3. Re: diffrent look graficstyle
Monika Gause Oct 19, 2014 9:46 AM (in response to Sentruper)You applied a graphic style?
Graphic styles are document specific. Maybe you changed it in the other document. Then you need to apply that change again in your current document. Or load the other graphic style in your current document.
4. Re: diffrent look graficstyle
Sentruper Oct 23, 2014 4:33 PM (in response to Monika Gause)thank you so much. I think this will be help. These are my first exercise with the graficstyle and maybe I saving a wrong graficstyle to the scribble-effect. So the information that the grafic styles are document specific is very important for me.
Greetings from Wiesbaden
5. Re: diffrent look graficstyle
Monika Gause Oct 23, 2014 4:46 PM (in response to Sentruper)Graphic styles that you need in every new document can be saved into your new document profile
Startup Profiles – A Great tool to Customize your New Documents « Adobe Illustrator blog
Good night from Hamburg
