18 Replies Latest reply: Oct 20, 2014 1:58 PM by Max Resnikoff RSS
    Loading Animation when form is submitting
    Max Resnikoff Community Member
      I have been looking for tutorials on how to have a loading animation show up when the form is submitted.
      But i found a problem: even if the data in the fields is empty or incorrect, the loading .gif still shows up.
      Is there a way to restrict the gif animation to only show when the form has gone through?
        • 1. Re: Loading Animation when form is submitting
          osgood_ CommunityMVP
          What are you using to send the form, php?
          You can set a variable once the form has been submitted successfully AFTER the mail(); function.
          $success = "True";
          Then where you want the animation to appear on the page:
          <?php if(isset($success)) { ?>
          gif image src goes here
          <?php } ?>
          Should work.
          • 2. Re: Loading Animation when form is submitting
            Would that work even with the action on another .php page?
            • 3. Re: Loading Animation when form is submitting
              It might do IF you integrate a $_SESSION variable into the mix but I don't know for sure.
              The process to test would be set the $_SESSION variable AFTER the form has been processed and before the redirect to the success.php or thankyou.php page.
              Include this at the top of the processing script page BEFORE any other code:
              <?php
              // Start the session
              session_start();
              Then after the mail(); function create a $_SESSION variable:
              $_SESSION['success'] = "True";
              Then redirect to the success.php page:
              header (Location: "success.php");
              Then on the success.php page:
              Again include this at the top of the page BEFORE any other code:
              <?php
              session_start();
              Then test to see if the $_SESSION variable has been set, include the code below where you want the gif animation to appear:
              <?php if(isset($_SESSION['success'])) } ?>
              src to animated gif goes here
              <?php } ?>
              What I tend to do these days is have the php processing script on the same page as the form and send the form page back to itself to be processed.
              • 4. Re: Loading Animation when form is submitting
                You also say:
                1) Is there a way to restrict the gif animation to only show when the form has gone through?
                Which is a bit different from:
                2) when form is submitting.
                I'm concerned now because the first request suggests you want the animation to play AFTER the form has been submitted while the second request suggests you want the animation to play WHILE the form is submitting.
                The solution I provided will only work AFTER the form has been submitted successfully.
                • 5. Re: Loading Animation when form is submitting
                  Nancy O. CommunityMVP
                  If you redirect users to a success.php page upon successful form submission, why not just put your animated GIF on the success.php page?
                  Nancy O.
                  • 6. Re: Loading Animation when form is submitting
                    because I want the Loading GIF to display as the form is submitting
                    • 7. Re: Loading Animation when form is submitting
                      Form submission takes a fraction of a second.  It's as close to instantaneous as you can get.  So I don't really understand what you're going for.
                      Nancy O.
                      • 8. Re: Loading Animation when form is submitting
                        my form seems to take 5-10 seconds to be submitted and redirected to the thank you page :/
                        • 9. Re: Loading Animation when form is submitting
                          That's sounds like a slow server.  Is this form hosted on a secure socket (https://)?
                          Nancy O.
                          • 10. Re: Loading Animation when form is submitting
                            it is on XAMMP
                            • 11. Re: Loading Animation when form is submitting
                              Xampp is a local testing server. You should test form processing on your remote server.
                              Nancy O.
                              • 12. Re: Loading Animation when form is submitting
                                bregent CommunityMVP
                                That does seem slow.
                                The form hasn't 'gone through' until you are redirected to the success page. So what you are asking for doesn't really make sense.
                                • 13. Re: Loading Animation when form is submitting
                                  I meant while the form is being submitted.
                                  • 14. Re: Loading Animation when form is submitting
                                    Tell us what you mean by 'gone through'.
                                    A form submission is complete when all data is passed from the form to the receiving document. In your case, this is a php document. Then the php code is executed. Typically this code will validate the form entries and call the mail function. So, where exactly do you want your animation?
                                    • 15. Re: Loading Animation when form is submitting
                                      Nancy O.
                                      Good point - thinking too deeply.
                                      I queried what the OP meant after that post because I guessed that despite the contradiction in their post this amimation was meant to be happening while the form was submitting not after the infromation has been successfully sent.
                                      I agee with you - seems a bit overkill as a form should only take a second to be processed BUT I have come across an animation while the form is being sent before, normally though on validation. Something spins around to show the user something is happening and I guess at times the server could 'hang' for a few seconds.
                                      Anyway my solutions WON'T work in that senario as the variable only detects the information has already been sent.
                                      • 16. Re: Loading Animation when form is submitting
                                        This is what i need:
                                        When the submit button is clicked, the SAME PAGE should fade, and the loading gif should appear. (top of the image below)
                                        Once the SUBMIT.PHP file completes the submission, then the page redirects to the thank you page. (The redirect to the thank you page is not a problem)
                                        • 17. Re: Loading Animation when form is submitting
                                          You're going to have to use a combination of php and Ajax/jQuery to process the form.
                                          Below is a very very simple unstyled example. (it has no validation on the form fields - that can be added)
                                          The code below is the form page down to </html> - the form action points to - form_mail.php - (the script processing page - included below after the form page code). You can put your animation in the 'loading' <div> instead of the message 'Sending your message....' After about 5-10 seconds another message will appear saying 'Your message has been sent'
                                          <!DOCTYPE HTML>
                                          <html>
                                          <head>
                                          <meta charset="UTF-8">
                                          <script src="http://code.jquery.com/jquery-1.10.2.min.js"></script>
                                          <script>
                                          $(function(){
                                          $('#sendEmail').submit(function(e){
                                          // process form information
                                          var thisForm = $(this);
                                          //Prevent the default form action
                                          e.preventDefault();
                                          //Hide the form after submit
                                          $(this).fadeOut(function(){
                                          //Display the "loading" message
                                          $("#loading").fadeIn(function(){
                                          //Post the form to the processing script
                                          $.ajax({
                                          type: 'POST',
                                          url: thisForm.attr("action"),
                                          data: thisForm.serialize(),
                                          //Wait for a successful response
                                          success: function(data){
                                          //Hide the "loading" message
                                          $("#loading").delay(5000).fadeOut(function(){
                                          //Display the "success" message
                                          $("#success").html(data).fadeIn();
                                          </script>
                                          <style>
                                          /* form css */
                                          #contact {
                                              width: 400px;
                                              margin: 0 auto;
                                          #contact input, #contact textarea {
                                              width: 300px;
                                          #contact #submit {
                                              width: 100px;
                                          #loading, #success {
                                          display: none;
                                          width: 100%;
                                          text-align: center;
                                          #loading h3, #success h3 {
                                          font-size: 25px;
                                          font-weight: normal;
                                          color: #000;
                                          </style>
                                          </head>
                                          <body>
                                          <div id="contact">
                                          <form method='post' id="sendEmail" action='form_mail.php'>
                                          <p>
                                          <label for="name">
                                          <input type="text" name="name" id="name" value="Name" onfocus="this.value=''">
                                          </label>
                                          </p>
                                          <p>
                                          <label for="email">
                                          <input type="text" name="email" id="email" value="Email" onfocus="this.value=''">
                                          </label>
                                          </p>
                                          <p>
                                          <label for="comments">
                                          <textarea name="comments" id="comments" cols="45" rows="5" onfocus="this.value=''">Comments</textarea>
                                          </label>
                                          </p>
                                          <p>
                                          <label>
                                          <input type="submit" name="submit" id="submit" value="SEND">
                                          </label>
                                          </p>
                                          </form>
                                          <div id="loading"><h3>Sending your message....</h3></div><!-- end loading -->
                                          <div id="success"><h3>Your message has been sent</h3></div><!-- end success -->
                                          </div>
                                          <!-- end contact -->
                                          </body>
                                          </html>
                                          This is the form_mail.php script:
                                          <?php
                                          if (isset($_POST['name'])) {
                                          // get name
                                          $name = trim($_POST['name']);
                                          // get email address
                                          $email = trim($_POST['email']);
                                          // get comments
                                          $comments = stripslashes(trim($_POST['comments']));
                                          $to = 'XXXXXXX@XXXXXXXXX.com'; // where you want to send the mail
                                          $from = 'mailservice@XXXXXXXXXXX.com'; // a valid address on your domain
                                          $subject = 'Comments from Website';
                                          $headers  = "From: $email\r\n";
                                          $headers .= "Reply-To: $email\r\n";
                                          //build message
                                          $message = "Name: $name\n\n";
                                          $message .= "Email Address: $email\n\n";
                                          $message .= "Message: $comments\n\n";
                                          $sent = mail($to, $subject, $message, $headers);
                                          echo "<h3>Your message has been sent.</h3>";
                                          • 18. Re: Loading Animation when form is submitting
                                            That seemes a bit coplicated for me to understand, as i am not knowledgable in Javascript.
                                            I have this, but how can i simply tell it to only display when the action has been called?:
                                            function ButtonClicked()
                                               document.getElementById("formsubmitbutton").style.display = "none"; // to undisplay
                                               document.getElementById("buttonreplacement").style.display = ""; // to display
                                               return true;
                                            var FirstLoading = true;
                                            function RestoreSubmitButton()
                                               if( FirstLoading )
                                                  FirstLoading = false;
                                                  return;
                                               document.getElementById("formsubmitbutton").style.display = ""; // to display
                                               document.getElementById("buttonreplacement").style.display = "none"; // to undisplay
                                            document.onfocus = RestoreSubmitButton;
                                            </script>
