1. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Oct 18, 2014 3:47 PM (in response to mdsbigpapa)Well, I'll be dipped in "...." Reply from Chat session I started. Am I thick headed to believe Adobe would have on-line tech support?
Amit Kumar: Regarding this issue, you need to go to forums.adobe.com
Mark Schuster: Really? Tech support cannot help?
Amit Kumar: We do not have chat support for it.
Mark Schuster: OK. Not pleased at all though.
Amit Kumar: Is there anything else I can help you with?
Mark Schuster: nope...
2. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
PRE_help Oct 20, 2014 3:47 AM (in response to mdsbigpapa)Hi,
You can disable the hardware acceleration and try to burn to DVD again. To remove the preference, go to Edit -> Preferences -> General -> Use Hardware acceleration.. uncheck this checkbox. You can turn this setting ON after you find an updated graphics driver.
Regards,
Premiere Elements Team
3. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Oct 20, 2014 9:36 AM (in response to PRE_help)I can however, the latest MS updates corrupted my boot block. I'm rebuilding my PC so it may be a few days to try again. Thanks.
PRE_help <forums_noreply@adobe.com> wrote:
PRE_help created the discussion
"How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13"
To view the discussion, visit: https://forums.adobe.com/message/6847134#6847134
4. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Oct 26, 2014 11:27 PM (in response to PRE_help)Unfortunately that didn't work. Same error "no plugin DLLs." Should I
have exited Premier or is the change dynamic?
Thanks for your time,
Mark
5. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
PRE_help Oct 27, 2014 12:07 AM (in response to mdsbigpapa)Hi,
The change does not ideally need an app restart, but if the error is still seen we suggest you save the project and restart it after disabling the hardware acceleration through the preferences.Regards,
6. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
rkclarke36 Oct 28, 2014 12:29 PM (in response to mdsbigpapa)Disabling hardware acceleration did not fix the problem!! I am experiencing the same problem. Just upgraded to Premiere Elements 13 (from 12), while burning DVD's it gives me this error code: plugincoder error: no plugin DLLs.
So frustrating!
I have an i7 processor with Nvidia Geforce graphics chip running Windows 8.1. I shouldn't be having any problems!!
7. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
A.T. Romano Oct 28, 2014 6:55 PM (in response to rkclarke36)rkclark36
While you are waiting for PRE_help to return to this thread for follow up, consider doing some classical troubleshooting just in case - if you
have not done this already....
Premiere Elements 13 on Windows 8.1 64 bit
Local Disk C
Users
Owner
AppData
Roaming
Adobe
Premiere Elements
13.0
and, in the 13.0 Folder, is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then delete the whole 13.0 Folder in which the Adobe Premiere Prefs file exists. Be sure to be working with Folder Options Show Hidden Files, Folders, and Drives active so that you can see the complete path cited.
By the way, is your error with burn to disc DVD or AVCHD?
Thanks.
ATR
8. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
A.T. Romano Oct 28, 2014 6:58 PM (in response to mdsbigpapa)Mark
As you await a reply from PRE_help, please give my "just in case" suggestion a try (please see reply to rkclark36 in post 7).
ATR
9. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
PRE_help Oct 28, 2014 10:27 PM (in response to rkclarke36)Hi,
The Hardware acceleration feature is only valid for machines that have Intel HD Graphics 2xxx and above as one of your graphics adapters. If that is not the case, this setting will not kick in and hence will not have any difference between the "checked" and "un-checked" states functionally. Are you able to burn the same project to DVD ISO? If you are able to do so, you can use any free external tool to burn the created ISO to DVD disc.
Internally, we have not seen this error for any other case other than the Intel accelerated ones.But in this forum thread some years ago, the solution was to reduce the resolution of the images used in your project. There is this thread in another forum that says that increasing the frame rate solved the problem. This can be done by choosing a different preset for burn. Please let us know if any of this solves your problem.
Regards,
10. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
A.T. Romano Oct 29, 2014 9:10 AM (in response to PRE_help)PRE_help
For Premiere Elements user, I would make note that the presets for burn to disc cannot be customized by the user within the program.
a. The second thread that you pointed rkclarke36 to does talk about resolving this issue by changing the burn to disc frame rate from
24 fps to 30 fps. But, that was for Premiere Pro, not Premiere Elements. In Premiere Pro, can the user really customize an Adobe burn to disc
preset?
If the burn to is to DVD disc for DVD-VIDEO, the user is
confined to two frames rate, 25 interlaced frames per second or 29.97 interlaced frames per second. But, he/she cannot change the frame rate
within the preset.
If the burn to is to DVD disc for AVCHD DVD, the user again meets different presets, but cannot change the frame rate within the preset. For Premiere Elements 13 burn to AVCHD disc, the presets are
H.264 1440 x 1080i NTSC Dolby
H.264 1440 x 1080i PAL Dolby
H.264 1440 x 1080p NTSC Dolby
H.264 1920 x 1080i NTSC Dolby
H.264 1920 x 1080i PAL Dolby
H.264 1920 x 1080p NTSC Dolby
Except for the two 1080p presets with frame rate of 23.976 progressive frames per second, the other presets all have a frame rate of 29.97 interlaced frames per second NTSC or 25 interlaced frames per second.
b. Mark has not yet offered the details of the Timeline content (video and/or stills) being taken to burn to DVD-VIDEO or AVCHD DVD. So, frame size as per your first mentioned link might be an avenue to pursue. I would include that with all my testing of Premiere Elements 4 to 13, I have not gotten this particular dll error
with any oversized stills.
ATR
11. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
PRE_help Oct 29, 2014 9:30 AM (in response to A.T. Romano)Thanks for pointing that out ATR. What I should have mentioned was to change the preset from an NTSC one to PAL,so that the frame rate changes accordingly from 29.97 -> 25 (or if it was PAL originally, change to NTSC preset and then attempt a Burn).
We have also not seen the plugin coder error internally in any other scenario other than a faulty driver for the Intel display adapter, when the hardware acceleration was checked. So the solution was
1. To disable the Intel Display adapter,
2. Update the Intel display driver or
3. Switch off the graphics acceleration setting from the preferences.
All these suggestions are valid only if one of the display adapters in the machine in question was an Intel HD Graphics 2xxx and above only. If there are multiple display adapters, even if one of them is the supported Intel adapter, the acceleration can kick-in, if checked in preferences.
Regards,
12. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
rkclarke36 Oct 29, 2014 11:09 AM (in response to mdsbigpapa)Problem Solved!!
Original problem: received errors and disc burn would freeze.
Originally received this error while burning: plugincoder error: no plugin DLLs
Then I removed a video file from the disc menu and started getting this error while burning: data rate of this file is too high for DVD
My laptop has multiple display adapters. Intel HD Graphics 4600 & NVIDIA GeForce GT 745M.
In the NVIDIA Control Panel there is an option to change your preferred graphics processor based on a program. I changed the setting ("select a program to customize") for Adobe Premiere Elements (had to Add the program to the list using the add button) and selected the preferred graphics processor for the program to be the NVIDIA processor. I also changed the global setting to use NVIDIA processor.
I restarted the computer and tried the burn again! Success!!
Thank you all for your input!
Ryan
13. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
A.T. Romano Oct 29, 2014 11:41 AM (in response to rkclarke36)Ryan
Glad for your success resolving your Plugin Coder Error: no plugin.dll and your customizing of your NVIDIA card's control panel.
However, I think that the following information posted earlier might have put the pieces together and have perhaps led to a success in another
ways?
Premiere Elements is known to have problems with computers that use more than 1 video card/graphics card.
I have not seen this message in a long time. What were the burn dialog's Quality area's readings for Space Required
and Bitrate. And, did you have a check mark next to "Fit Content To Avoid Space". The history on that message has
classically been
a. remove the check mark next to Fit Content to Available Space and adjust the Bitrate from max 8.00 Mbps downward
until you no longer get the data rate message. Lower the Bitrate, lower the file size, lower the quality. You can get away
with a little lowering of the Bitrate before any noticeable change in end product quality.
But none of the above was put into the problem equation at the onset. Curious that all this invoked the Plugin Coder Error:
no plugin.dll message in the mix.
Just some thoughts to consider. Right now you have success and are moving forward in your projects. Very good news.
ATR
14. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Nov 1, 2014 12:48 AM (in response to PRE_help)Sorry about the delay but Patriot Guard Missions took precedence I traveled to Hamilton Ont., Ca. to honor Cpl. Nathan Cirillo. I've been busy creating a video from my dash cam so my time away from my original project has suffered. The video I created for Cpl. Cirillo was a youtube video and not a DVD creation.
Further, the original project for another PGR mission was lost with the OS failure from MS, I haven't fully recreated it but I have compiled a video from my dash cam that I hope to give to the widower. From there I'll recreate the compiled video of photos and dash cam videos.
As for my hardware configuration: I have an HP EliteOne 800 i5 processor with an Intel HD Graphics 4600 display adapter - driver version 10.18.10.3907 (dated 2014-08-05) and my second monitor is a Dell 2007FP(Digital).
As of this posting I've followed A.T.'s directions in #7 and started the burn process of the dash cam videos. It's encoding media right now.
More later...
15. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Nov 1, 2014 2:23 PM (in response to mdsbigpapa)Well deleting just the Adobe Premiere Elements Prefs file did not help. Still received the no dlls message - just restarted PE 13 and noticed that hardware acceleration was checked. I guessing that my failure also had that checked. I just unckecked it and will start another burn process.
DVD parameters: [Note: I'm burning this DVD without any menus]
DVD
burn to: disc [Note: I have a Memorex 4.7GB DVD+R disc]
Disc Name: Karen Rosell dash cam 20140923
burner location: Z: hp DCDVDW-SN-208DB
Copies: 1
Status: Ready
Presets: NTSC_Widescreen_Dolby DVD
Quality: (checked) Fit Contents to available space
Space required: 4.37GB(Bitrate 4.77Mbps)
This video is 1:58:29 in length. [Note: My original copulation of photos and dash cam was only 28 minutes in length.]
16. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
A.T. Romano Nov 1, 2014 3:07 PM (in response to mdsbigpapa)mdsbigpapa
Thanks for the update.
Your disc appears to be DVD 4.7 GB/120 minutes. From your Space Required/Bitrate data shown in post 15, your Timeline content should be too much on that disc to give you a good quality end product.
Do you have a DVD 8.5 GB/240 minutes disc to use for this burn to? Curious to see the effects of that on your issues.
Just in case I had not mentioned it earlier...the 4.7 GB disc is in reality 4.38 GB and the 8.5 GB disc is in reality 7.95 GB.
Looking forward to your results. Thanks for considering the troubleshooting suggestions.
ATR
17. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Nov 2, 2014 7:22 PM (in response to A.T. Romano)ATR,
Thanks for the tip. My grandson used my last 8.5GB DVD so I'll have to invest in another batch. ??: Will an average DVD player play a double-layer DVD without issues?
I got a successful burn with Hardware Acceleration unchecked and quality isn't too, too bad. Some pixelation occasionally but it's hard to tell if it isn't my system causing it because it's not always consistent on the video. I do have to check my dash cam to see if "Anti-shake" is set - I believe it is though.
I created an ISO and mpg of my original PREL but they are only drafts and quality is poor, so I'll be able to reverse engineer my photo and dash cam compilation. Now it just reserving the time to get it done. I should see the widower on Veterans Day so that will be my goal. I will update this thread with the outcome of my compilation DVD.
Thanks everyone for your assistance. More later... I'll be monitoring this thread so if there are any other suggestions, I'll be sure to see them.
BP (Big PaPa)
18. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
A.T. Romano Nov 2, 2014 7:41 PM (in response to mdsbigpapa)mdsbigpapa
Most regular DVD players should support playback of DVD-VIDEO on a DVD double layer side sided disc.
But, DVD players can differ in specifications and compatibility as to disc type and supported format on a disc type.
And, some disc brands have higher reliability than others.
Not sure if it is practical for you to explore but....you could export your Timeline content to a file saved to the computer hard drive.
And, from there project the file's playback from a computer player to a screen, using a projector.
Best wishes with this project which will be cherished by the widower and family
ATR
19. Re: How do I correct the error; "PluginCoder error: no pligin DLLs" when attempting to burn a DVD with Premiere Elements 13
mdsbigpapa Nov 3, 2014 12:34 AM (in response to A.T. Romano)OK, so I fibbed...And lost a few hours sleep in the process. However, I re-engineered my PREL and got a successful burn of a DVD for my compilation video. I chose not to use menus as there aren't any good break points to take advantage of in the video.
Hardware Acceleration was NOT checked for this exercise. I unchecked Fit contents to DVD and moved the slider to maximum for best quality. All-in-all, for a rookie, I'm pleased with the final package and I'm sure Forrest will be as well. I'm going to play with different MPEG parameters to see what an MPG file looks like and I may even create another ISO to make copies in the future, should Forrest want additional copies.
Again, thanks for your help...
Mark
