1. Re: FrameMaker 12 UI is unusable on my laptop's screen but OK on an external monitor
Arnis Gubins Oct 20, 2014 5:56 AM (in response to JeffMattson)Do you have a specific monitor size specified in your Preferences? If so, just delete the value and FM will autoscale.
Also, you can can create custom workspaces for the laptop vs monitor scenarios so that layouts are optimized for each environment.
2. Re: FrameMaker 12 UI is unusable on my laptop's screen but OK on an external monitor
JeffMattson Oct 20, 2014 10:41 AM (in response to Arnis Gubins)Thanks, but I'm not specifying a monitor size in Preference. If I do, it makes the UI even smaller. But even if I choose "Default," the UI is too small with lots of glitches.
3. Re: FrameMaker 12 UI is unusable on my laptop's screen but OK on an external monitor
Arnis Gubins Oct 20, 2014 11:02 AM (in response to JeffMattson)What resolution is your laptop screen and are you using the small or large icon set?
4. Re: FrameMaker 12 UI is unusable on my laptop's screen but OK on an external monitor
JeffMattson Oct 22, 2014 10:37 AM (in response to Arnis Gubins)I just tried using FrameMaker on my laptop this morning and now it looks OK. Thanks! Maybe I needed to restart my computer after setting the Monitor Size to Default?
FWIW, the laptop screen size is 1920 x 1080, and the icons are regular size.
5. Re: FrameMaker 12 UI is unusable on my laptop's screen but OK on an external monitor
Matty777 Oct 23, 2014 12:32 PM (in response to JeffMattson)I starting having the same problem yesterday, and I had been on the same monitor. Have you figured out a solution?
