1. Re: CRX operations giving error when invoking from Form
WASIL Oct 21, 2014 1:57 AM (in response to dnbalaji)Make sure you are pointing to the correct URL over which the form is submitted.
-Wasil
2. Re: CRX operations giving error when invoking from Form
dnbalaji Oct 21, 2014 6:46 AM (in response to WASIL)Hi Wasil,
Thanks for your response.
I have checked in the form and the URL that is pointing to is correct. I am able to call the process from the form, only when executing the CRX operation I am getting the error. I have other few operations in the same process which are getting executed without any issues. Let me know your inputs on this.
Balaji
3. Re: CRX operations giving error when invoking from Form
WASIL Oct 21, 2014 6:11 PM (in response to dnbalaji)What error do you see in the server logs ? Paste here.
If possible, you can attach a sample LCA and form which shows this error.
Wasil
4. Re: CRX operations giving error when invoking from Form
dnbalaji Oct 22, 2014 4:16 AM (in response to WASIL)Hi Wasil,
For some reason I am not able to paste the logs here. Can you please send me any ID to which I can mail you the logs?
Balaji
5. Re: CRX operations giving error when invoking from Form
WASIL Oct 23, 2014 5:24 PM (in response to dnbalaji) -
6. Re: Re: CRX operations giving error when invoking from Form
WASIL Oct 24, 2014 9:20 PM (in response to dnbalaji)Attached here is a sample process LCA which works fine when invoked using a form or workbench.
Wasil
StroeStringInCRX.lca.zip 15.0 K
