1. Re: Setting up a CanoScan 8800F with PSE13.
andaleebfatima1 Oct 20, 2014 1:41 AM (in response to Gennie2281)Hi,
Can you please explain whether you are trying to import in Elements Organizer or in Editor?
Andaleeb
2. Re: Setting up a CanoScan 8800F with PSE13.
Gennie2281 Oct 20, 2014 2:56 AM (in response to andaleebfatima1)I use the Editor to import scanned images. Experience in previous versions taught me the Organiser likes to do it's own thing and that doesn't necessarily match what I want to do.
3. Re: Setting up a CanoScan 8800F with PSE13.
~bridge_mastero~ Oct 20, 2014 11:44 PM (in response to Gennie2281)Hi ,
1)First Move your TWAIN plugin from "C:\Program Files \Adobe\Photoshop Elements 13\Optional Plug-Ins\Import-Export" to "C:\Program Files \Adobe\Photoshop Elements 13\Plug-Ins"
2)Now Install Its driver from canon website.
If it runs only on WIA then itself please update once your driver.
4. Re: Setting up a CanoScan 8800F with PSE13.
nealeh Oct 21, 2014 4:10 AM (in response to ~bridge_mastero~)~bridge_mastero~ wrote:
1)First Move your TWAIN pluginNo - COPY the plug-in. If you move it, it can prevent future updates from installing. Full details at TWAIN not installed | Photoshop Elements 9 and later.
Cheers,
Neale
5. Re: Setting up a CanoScan 8800F with PSE13.
Gennie2281 Oct 21, 2014 3:57 PM (in response to nealeh)Thank you, gentlemen, for your replies. Unfortunately both appear to rely on previous versions of PSE being available. Unfortunately I deleted all previous versions of PSE when I installed v13. I have Googled but don't seem able to find a site where I can download the plug-in. I have contacted Canon Australia and they can't help. They suggested it may have come from Adobe? If not, can you suggest where I can get the plug-in or how I can get the WIA working properly with both the scanner and PSE13. As it is the WIA option is completely unacceptable.TIA
6. Re: Setting up a CanoScan 8800F with PSE13.
Gennie2281 Oct 22, 2014 12:51 AM (in response to Gennie2281)I have Windows on automatic updates and the WIA driver had not been updating. I have now updated the driver and it is somewhat improved but automatically saves the image as a bitmap eg IMG123.bmp. I would still prefer to use the twain drivers if I can find them as I have far more control over choices etc. I don't have disks for previous versions of PSE. I downloaded the program for quite a few versions.
7. Re: Setting up a CanoScan 8800F with PSE13.
nealeh Oct 24, 2014 3:34 PM (in response to Gennie2281)The 32-bit version of PSE13 includes the TWAIN drivers as described in the post I linked to. Look again.
Neale
8. Re: Setting up a CanoScan 8800F with PSE13.
Gennie2281 Oct 24, 2014 4:31 PM (in response to nealeh)I did look, and I've updated drivers from Canon. This is what my screen shows.
on the file menu, it shows Import > WIA ... and this is the dialog box that is displayed. BTW Windows optional drivers have been updated.
I don't know if this is the way it's supposed to look as I've rarely used it.
I tried using My Preferences to set the optional plug in but that didn't work plus I then lost access to my Topaz Labs plugins and it wouldn't let me set two optional plug in drives. Oh, BTW I am definitely a 32 bit user & have both Adobe & Windows on automatic updates.
It is over 13 years since I worked on our network helpdesk and I can appreciate how frustrating this is for you and I do appreciate your help. I have tried just about everything I can find on the Adobe website and I just cannot understand why the Elements is not locating the driver. I haven't had this problem before and I've been using Elements from Version 2. Admittedly I didn't scan much then but I do a lot of scanning now which is why I'm so frustrated and am frustrating you.
9. Re: Setting up a CanoScan 8800F with PSE13.
Barbara B. Oct 24, 2014 7:25 PM (in response to Gennie2281)Okay, so you found the plug-in and the Import-Export folder. Now you need to copy it to the regular plugins folder in PSE (at the same level as the Optional Plugins folder) and restart your computer.
10. Re: Setting up a CanoScan 8800F with PSE13.
Gennie2281 Oct 24, 2014 7:55 PM (in response to Barbara B.)Thank you everyone for your help, it finally works, funnily enough with both the WIA driver and the TWAIN driver. The WIA driver no longer automatically saves the image with an IMG###.bmp name but displays the image as untitled and allows me to make the decision about name & format. Contrary to Barbara's instruction I only needed to relaunch PSE13. Woo Hoo.
