This content has been marked as final.
Show 4 replies
1. Re: How to save a layer as an alpha channel?
shumicse Oct 20, 2014 2:25 AM (in response to Monstrik)I dont know it will help you out or not, still sharing the instructions from where I get the idea of saving the layer here. Hope you will find it helpful.
- Make the Channels panel the active panel.
- Alt + click (Option + click) the Create New Channel icon
at the bottom of the Channels panel. - In the New Channel dialog box, type a relevant name.
- If most of the image is to be masked (not selected), click the Masked Areas radio button. If most of the image is to be selected, click the Selected Areas radio button.
- If desired, click the Color box to change the overlay color.
- Leave Opacity 50%, unless you desire otherwise.
- Click OK.
- The document window will be filled with either solid black if Masked Areas was chosen or solid white if Selected Areas was chosen.
- Make the composite color channel active by clicking in the visibility area and displaying its eye icon
. - If Masked Areas was chosen...
- The document window will show the image covered by the overlay color.
- Type the letter d to make the foreground and background colors the default black and white
. - If white is not the foreground color, type the letter x until white is the foreground color
. - Type the letter b to make the Brush tool
the active tool. - Using a brush size and softness of your choice, paint in the document window. Wherever you paint with white paint, the mask will be erased. Any part of the image not covered by the overlay color is being selected. Painting with gray paint will partially select an area.
- If Selected Areas was chosen...
- The document window will show the image normally.
.. - If black is not the foreground color, type the letter x until black is the foreground color.
the active tool. - Using a brush size and softness of your choice, paint in the document window. Wherever you paint with black paint, the image will be covered by the overlay color. Any part of the image covered with the overlay color is being masked, or de-selected. Painting with gray paint will partially de-select an area.
- Repeat steps 2 through 11 as many times as needed to create individual custom selections.
- When finished, turn off the visibility of the alpha channel by clicking the alpha channel's eye icon
. - Make the Layers panel the active panel by clicking the Layers tab.
- When the file is next saved, the alpha channel(s) will also be saved.
2. Re: How to save a layer as an alpha channel?
normfb Oct 20, 2014 4:53 AM (in response to Monstrik)Go to the layer and Select > All
Edit > Copy
Go to Channels panel and click on Create New Channel Symbol at bottom of panel
Option click on the black rectangle Alpha 1 in the Channels panel
Edit> Paste
3. Re: How to save a layer as an alpha channel?
normfb Oct 20, 2014 1:57 PM (in response to normfb)Please click Correct if my response solved your problem, or post a reply if it did not.
4. Re: How to save a layer as an alpha channel?
shumicse Nov 11, 2014 1:33 AM (in response to Monstrik)I guess it should be solved now. That process works for me.
