8 Replies Latest reply on Oct 21, 2014 5:17 AM by Unique
    Find the maxi height of the rectangle on a page
    Unique Level 1
      Hi Forum,
      Your help is much appreciated.
      I would like to check the rectangle which is the tallest of all, on each and every page, and write it in a txt file.
      Here is my try. I can write only the first page rectangle height.
      writeData();
      function writeData (aData )
                  tt= [];
          myFile = new File("/Users/astudio/Desktop/Info/rectangle.txt");
          if( myFile!='' )
              //Open the file for writing.
              myResult = myFile.open( 'w', undefined, undefined );
      rct  = app.activeDocument.pages.everyItem().rectangles.everyItem().getElements();
      for(i=0; i<rct.length; i++) {
      rcc =     rct[i].rectangles.everyItem().getElements()
      tt.push((rct[i].geometricBounds[2]-rct[i].geometricBounds[0]));
      var myarray = tt;
      var tf = myarray.sort(SortLowToHigh).pop();
      myFile.writeln(rct[i].geometricBounds[2]-rct[i].geometricBounds[0]);
      function SortLowToHigh(a, b)  {
      if (a > b) return 1;
      else if (a < b) return -1;
      else return 0;
      myFile.close();
      continue;                /// I can't able to write the maximum height of the rectangle for next next pages..... one below the other in Text file.
      Please help me out to get this done.
      thanks very much.
        • 1. Re: Find the maxi height of the rectangle on a page
          Unique Level 1
          Sorry forum a small correction
          However it writes all the rectangles heights and not the tallest of all.
          thanks.
          • 2. Re: Find the maxi height of the rectangle on a page
            Unique Level 1
            Again, forum for more Information...
            I tested, it writes like this.
            30.5671641790929
            18.1492537313365
            16
            9.50000000000001
            44.6567164181409
            26.5149253732712
            but,
            page 1 rectangles height.....
            30.5671641790929              // I need to write only the tallest rectangle of page 1
            18.1492537313365
            page 2 rectangles height
            16                                         // I need to write only the tallest rectangle of page 2
            9.50000000000001
            page 3 rectangles height
            44.6567164181409         // I need to write only the tallest rectangle of page 3
            26.5149253732712
            thanks forum.
            • 3. Re: Re: Find the maxi height of the rectangle on a page
              Kai Rübsamen Adobe Community Professional
              He, why don’t you use the code-editor?
              To find the tallest rectangle on every page, I would do something like:
              var curDoc = app.activeDocument;
              var allPages = curDoc.pages;
              var list = [];
              for ( var p = 0; p < allPages.length; p++ ) {
                  var curPage = allPages[p];
                  var curPageRectangles = curPage.rectangles;
                  var theTallestHeight = curPageRectangles[0];
                  for ( var r = 1; r < curPageRectangles.length; r++ ) {
                      var curRect = curPage.rectangles[r];
                      if ( curRect.visibleBounds[2] - curRect.visibleBounds[0] > theTallestHeight.visibleBounds[2] - theTallestHeight.visibleBounds[0] ) {
                          theTallestHeight = curRect;
                  list.push( "Page " + theTallestHeight.parentPage.name + ": " + String( theTallestHeight.visibleBounds[2] - theTallestHeight.visibleBounds[0] ) );
              alert ( list.join( "\r" ) );
              • 4. Re: Find the maxi height of the rectangle on a page
                Unique Level 1
                Hi
                Thanks for your valuable support.
                Kai, I have a doubt on this. When i tried to retain only the tallest rectangle on page, deleting other. The script doesn't consider the recently added tallest rectangle.
                The recently added rectangle hasn't been considered as Item(0) (curPageRectangles[0];).
                Any help please.
                THanks for your support on time. timely indeed.
                • 5. Re: Find the maxi height of the rectangle on a page
                  Hm, sorry but I did not understand the problem … maybe some advanced scripters see something that I’m not aware of.
                  Assume you have 4 rectangles. The script take curDocRectangles[0] and assumes, that this one is the tallest one.
                  If you create a new rectangle, this new one get the index 0. So if you start the script again, this rectangle will be check at first.
                  So, if you have a problem with this, try to built a example, where the script goes wrong and try to describe in good english your steps.
                  – Kai
                  • 6. Re: Find the maxi height of the rectangle on a page
                    Unique Level 1
                    Kai, thank you so much for your extensive support.
                    I'm really sorry for the communication issue.
                    Please bear with me for the inconvenience.
                    I will update you, what Im trying to get from you.
                    thanks for the support kai.
                    • 7. Re: Re: Find the maxi height of the rectangle on a page
                      Unique Level 1
                      Hi kai,
                      I'm just trying to delete all the smallest height rectangles leaving the tallest one intact.
                      The script edited (the one you helped me).
                      var list = [];
                      if(curRect.visibleBounds[2] - curRect.visibleBounds[0]!=String( theTallestHeight.visibleBounds[2] - theTallestHeight.visibleBounds[0] )) {
                        curRect.remove();
                      As you said, Let's assume, I have 4 rectangles on each pages, with different heights.
                      After running the edited script (above), only 1 smallest height rectangle is deleted on all the pages.
                      My intention is to delete all the 3 smallest rectangle, except the 1, the tallest rectangle on each page.
                      Thanks for the support Kai,
                      • 8. Re: Find the maxi height of the rectangle on a page
                        Unique Level 1
                        Hi Kai,
                        Thanks for your help & support.
                        Temporarily I have found something like this. Just tweaked your script.
                        Please correct me if I went wrong here.
                        var list = [];
                            for ( var r = 1;  r<curPageRectangles.length-1;  r++) {
                        if(curRect.visibleBounds[2] - curRect.visibleBounds[0]<String( theTallestHeight.visibleBounds[2] - theTallestHeight.visibleBounds[0] )) {
                                try {
                        do(curPage.rectangles[r].remove());
                        while(curPageRectangles[0]!=0 )
                        } catch (e) {}
                        Kai, kindly correct the above script, to do much better & prettier.
                        Thanks for your support Kai.
